RobK Posted July 15, 2005 Report Share Posted July 15, 2005 Anyone know if you can enable logging for terminal services access, like when sessions are created and disconnected or reset? Link to comment Share on other sites More sharing options...
Hopsta Posted July 15, 2005 Report Share Posted July 15, 2005 Only logon auditing I know of is within the Security Event logs. You could just write a script which logged the comings and goings, on log on/off to a file. Something like - echo %username% >logon.txt echo date >>login.txt echo time >>login.txt A tad rudamentry, but would do the job, only issue would be the file gettnig massive after a while, so would need to run a task to clear the file once in a while Graham Link to comment Share on other sites More sharing options...
Belchy Posted July 15, 2005 Report Share Posted July 15, 2005 open up the local policy editor start > run > gpedit.msc and edit the local policy to audit account logon activity. The policy is under computer configuration>windows settings>security settings>audit policy and is called "audit logon events" . Select success and failure for a true picture Link to comment Share on other sites More sharing options...
RobK Posted July 15, 2005 Author Report Share Posted July 15, 2005 Thanks for that, but I was thinking about logging the TS sessions themselves. We have a system which runs apps in a disconnected TS session and the sessions occasionally get reset for no apparent reason. It would be handy if it would log when the session is closed and why. Link to comment Share on other sites More sharing options...
Belchy Posted July 15, 2005 Report Share Posted July 15, 2005 have you checked your RDP settings for timeouts? Link to comment Share on other sites More sharing options...
RobK Posted July 15, 2005 Author Report Share Posted July 15, 2005 Aha, just found there was a group policy that set the "end a disconnected session" setting to 1 day! It's odd because it didn't show up in the connection settings on the server Well that shoud sort it, cheers guys Link to comment Share on other sites More sharing options...
