delta Posted August 2, 2005 Report Share Posted August 2, 2005 Hi just bought a vw caddy, extremely sore on MPG, wish to set up timing, has anyone got a photograph of the actual flywheel timing mark as there seems to be 3 possible marks? Link to comment Share on other sites More sharing options...
Tobes49 Posted August 4, 2005 Report Share Posted August 4, 2005 Should have the number 0 stamped in the flywheel. On the belt end the bolts for the pully there will be a holes between the bolts and you should have a locating notch in one hole this should be about 6-7 o'clock postition. Or remove inj 1 or 4 and use something to feel when the pistsion is at the top then the mark should be around there. Link to comment Share on other sites More sharing options...
delta Posted August 4, 2005 Author Report Share Posted August 4, 2005 Thanks, will check that out over the weekend Link to comment Share on other sites More sharing options...
