pugboy Posted September 25, 2005 Report Share Posted September 25, 2005 Hi, My recently aquired Passat is missing its boot mounted CD autochanger. Have had a look on Ebay, but the autochangers are making silly money. So I might as well fit an aftermarket headunit. After much searching for a headunit that had a blue display to match the dash I'm now wondering what adapters I need? I'm confident I need the VW wiring adapter to save cutting any wires, but do I need an aerial adapter? Cheers. Link to comment Share on other sites More sharing options...
Tobes49 Posted September 25, 2005 Report Share Posted September 25, 2005 You shouldn't need an adapter for the power wires as VW use the standard head unit ISO plugs, you might have to change a wire over but that about all, You will need a aerial adapter. Link to comment Share on other sites More sharing options...
pugboy Posted September 25, 2005 Author Report Share Posted September 25, 2005 Cheers. So I would have been paying a tenner for a wiring adapter I didn't need! That single wire that might need swapping - is that the contsant power and ignition power one? When you say aerial adapter do you just mean the single plug? Link to comment Share on other sites More sharing options...
mulkbear Posted September 25, 2005 Report Share Posted September 25, 2005 here is a diagram of what wires you need the change over. Link to comment Share on other sites More sharing options...
pugboy Posted September 25, 2005 Author Report Share Posted September 25, 2005 Cheers mate. Had to do that when fitting a CD player to my Mums Daewoo Matiz last year (even when using an adapter?!). Link to comment Share on other sites More sharing options...
asta Posted September 27, 2005 Report Share Posted September 27, 2005 [ QUOTE ] Cheers. So I would have been paying a tenner for a wiring adapter I didn't need! That single wire that might need swapping - is that the contsant power and ignition power one? When you say aerial adapter do you just mean the single plug? [/ QUOTE ] single plug yeah. Its £4.29 from Halfords. Sometimes you get them with new headunits. if you want lw/mw you also need a signal splitter. Link to comment Share on other sites More sharing options...
chrisbas Posted September 27, 2005 Report Share Posted September 27, 2005 There's 2 adaptors 1: VW and Audi 2: Volkswagon. I fitted the vw audi one and had to change the wires around, but then fitted the Volkswagon adaptor and it plugged straight in without messing with any wires. Hope this helps. Link to comment Share on other sites More sharing options...
