kl114 Posted October 1, 2005 Report Share Posted October 1, 2005 Hi all, I got a R reg 1.8 Sport, the anti-freeze/coolant tank seems to be low (well below MIN), I've checked no leak under bonnet, anyone knows what caused that? But temperature seems ok, always at 90 when running. Checked manual, it says shouldnt use other coolant apart from the VW's one, any advice on buying VW coolant or those you can get from Halfords? How much roughly from VW? Thanks Link to comment Share on other sites More sharing options...
Rustynuts Posted October 1, 2005 Report Share Posted October 1, 2005 VW coolant is not compatible with any other stuff, don't even top it up with a little bit. The dealers sell it, and it's good stuff but you can't buy it from Halfords. It's not too expensive either so have a drive to your local VW parts dept, and they'll sell you some. I'd top it up, then start looking for leaks if it drops again. Link to comment Share on other sites More sharing options...
jonboy3020 Posted October 6, 2005 Report Share Posted October 6, 2005 £5.86 for 1.5 litres, advise just using water if its only dropped a bit as G12 is very strong Link to comment Share on other sites More sharing options...
pontyslapper Posted October 6, 2005 Report Share Posted October 6, 2005 G12 is the dogs danglys - its so good I put it in the wife's ford escort (needs to be done after a full drain and flush). Just a shame that the bloody water pump is knackered. Only thought it was a pipe split or a jubilee clip needing tightening. Needless to say - when its sorted it'll be running G12 again. Link to comment Share on other sites More sharing options...
