UBM Posted October 2, 2005 Report Share Posted October 2, 2005 Anyone got one or got access to one - I still can't get the sidelight bulbs out! Link to comment Share on other sites More sharing options...
alarming Posted October 2, 2005 Report Share Posted October 2, 2005 See below, I believe these instuctions are for a B7 with Halogen Headlights, the numbers refer to pictures but there are to many to post Removing Left headlight: If fitted, detach cover -1- on left of engine compartment. Take connectors -1- and -2- out of holder. Unclip holder for connectors and pull off upwards -arrow-. Right headlight: If fitted, detach cover -1- on right of engine compartment. Screw out bolts -arrows-. Disengage activated charcoal filter solenoid valve -N80 -1- at air duct. Remove air duct -2-. Both sides Detach cover for main beam from headlight housing. Release headlight range control motor: At right headlight by turning anti-clockwise -arrow -; at left headlight by turning clockwise. Note: Headlight range control motor need not be removed. Release the two retainer tabs and pull holder -arrow- out of housing. Pull side light bulb out of holder. Installing Install in reverse order, paying attention to the following: Insert new bulb in holder, taking care not to touch glass bulb with bare hands. Lock headlight range control motorin position. Close housing cover and secure with spring clip. Link to comment Share on other sites More sharing options...
UBM Posted October 3, 2005 Author Report Share Posted October 3, 2005 Cheers buddy - you have PM! Link to comment Share on other sites More sharing options...
alarming Posted October 4, 2005 Report Share Posted October 4, 2005 You've got PM Link to comment Share on other sites More sharing options...
UBM Posted October 4, 2005 Author Report Share Posted October 4, 2005 Cheers Custom - still can't swap - these instructions are for models with the sidelight on the bottom. Link to comment Share on other sites More sharing options...
alarming Posted October 4, 2005 Report Share Posted October 4, 2005 I think they might be for the B6! Link to comment Share on other sites More sharing options...
UBM Posted October 4, 2005 Author Report Share Posted October 4, 2005 Thanks for looking Custom. Please, someone, HELP.... Link to comment Share on other sites More sharing options...
