james1978 Posted October 2, 2005 Report Share Posted October 2, 2005 I brought an R32 last week,And today the passenger door lock came off in my hand.I was told by the previous owner someone tryed to break in to the car,And the damage was repaired.Does anybody know why it's not fixed,And how i go about repairing it. P.s cant see how it can be fixed into position. Link to comment Share on other sites More sharing options...
Zenyck100 Posted October 2, 2005 Report Share Posted October 2, 2005 i just the same problem. my passenger door lock barrel came loose and couldnt be re-fitted took the car to my local VW dealer and they fitted a new handle retainer to the inside of the door all under warranty. Link to comment Share on other sites More sharing options...
james1978 Posted October 2, 2005 Author Report Share Posted October 2, 2005 Cheers for replying Zenyck100. Can you tell if it was a big job?,Or do you know what they had to do? Thanks.. Link to comment Share on other sites More sharing options...
Zenyck100 Posted October 2, 2005 Report Share Posted October 2, 2005 wasnt a big job. took the dealer bout an hour. the door card has to come off, then theres another panel which has to be removed to get to the door lock area. is your cr under warranty?? Link to comment Share on other sites More sharing options...
james1978 Posted October 2, 2005 Author Report Share Posted October 2, 2005 The car has 15 months warranty left,But if they think the damage has been done by someone trying to break in,They might not cover it,I'll just have to try. Thinking about delocking it anyway,Does anyone have any tips on getting the lock sprayed? Link to comment Share on other sites More sharing options...
Dan32 Posted October 2, 2005 Report Share Posted October 2, 2005 Was it the door lock or the door handle? I only ask because mine only has door lock on drivers side and came as standard with passenger door lock blanked. Supposedly there is a way to take out the lock barrel without taking the door apart. You'll have to do a search because I can't remember how but something to do with a screw in the door that holds the barrel in place. Link to comment Share on other sites More sharing options...
james1978 Posted October 3, 2005 Author Report Share Posted October 3, 2005 Just been to vw,(booked in for monday),The fella said theres a c clip,which if you undo the screw on the inside,It falls into the inside of the door.So that means the door panel will have to come off. Thanks for your help guys. Link to comment Share on other sites More sharing options...
larryccf Posted October 3, 2005 Report Share Posted October 3, 2005 for just the key cylinder, don't believe the door panel has to come out there's a torx screw head showing in the rear edge of the door slightly above the lock striker that has to be loosened i replaced my driver side lock with a blanking kit and spent an hour pulling the panel before i discovered the screw just needed to be loosened - it's about a 10 minute affair once you've done it once do a search here and on vwvortex - there's a pictorial write up in one of the strings Link to comment Share on other sites More sharing options...
james1978 Posted October 3, 2005 Author Report Share Posted October 3, 2005 Its the 'torx screw' your talking about that fell into the door,That means theres nothing to hold the barrel in place. Link to comment Share on other sites More sharing options...
mb Posted October 4, 2005 Report Share Posted October 4, 2005 Its not the torx screw that drops - there is a section of the lock cylinder that has to tigthen up correctly to engage the lock cylinder into teh door this is what is referred to as the "c" clip. It is highly unlikely that the "c" clip has fallen into the door, but if the screw is undone too far or wobbled the "c" clip drops out of alignment and then the only way secure the lock cylinder into the door is to strip the door and re-engage the c-clip and tighten everything up properly. Link to comment Share on other sites More sharing options...
larryccf Posted October 5, 2005 Report Share Posted October 5, 2005 you just woke my memory up correct, the torx screw does not come all the way out when unscrewing you'll feel a "stop" or a point where you'll feel increased resistance to further counterclockwise turning at that point, stop unscrewing again, there's a real good pictorial instruction set that is linked in one of the other strings on this board on this very subject Link to comment Share on other sites More sharing options...
