lj329 Posted October 10, 2005 Report Share Posted October 10, 2005 Hi all, I have got a 1999 T plate diesel passat that has developed a fluid leak in the last couple of weeks. What looks like water is dripping from the area underneath the passenger footwell. It is coming from what looks like a small sump plate that is about 30cm in from the rear of the OSF tyre. I haven`t noticed any drop in any fluid levels and there are no warning lights on the dash. The stuff is clear and odourless so I was thinking perhaps it is condensation from the aircon. The aircon is working fine though. I can`t really quantify how much water is dripping but it is enough to leave a small puddle that appears by ths OSF tyre and is instantly noticible. The question is should I be bovvered and is there anything I can check or do ?? Thanks as always Lj Link to comment Share on other sites More sharing options...
mulkbear Posted October 10, 2005 Report Share Posted October 10, 2005 sounds very much like the air con drain pipe dripping. Does the vehicle has a sun roof Link to comment Share on other sites More sharing options...
lj329 Posted October 10, 2005 Author Report Share Posted October 10, 2005 No there isn`t any sunroof Link to comment Share on other sites More sharing options...
BFC Posted October 11, 2005 Report Share Posted October 11, 2005 I believe that it is just condensation. I have had this on all my cars with aircon especially when the outside temp is warm. I enquired initially at the stealer who advised it is just condensation. Link to comment Share on other sites More sharing options...
lj329 Posted October 11, 2005 Author Report Share Posted October 11, 2005 Thanks Guys, Is there any reason why the leak seems to have increased recently, the weather has not been particularly warm and I usually set the climate to a cosy 22/23 degrees ? Cheers Link to comment Share on other sites More sharing options...
pritesh Posted October 11, 2005 Report Share Posted October 11, 2005 when did you last have your system serviced? it may be due for its service? Link to comment Share on other sites More sharing options...
Wobby Posted October 11, 2005 Report Share Posted October 11, 2005 Wont more condensation mean the temperature differance is greater? So the system is working fine (my opinion). I sometimes get quite a large puddle under mine, but only if i have been using the aircon on lowest setting for a long run Link to comment Share on other sites More sharing options...
lj329 Posted October 11, 2005 Author Report Share Posted October 11, 2005 Oh well, everything else looks fine - the aircon is cold and the drive is on top form (after sticking on a new maf), so i ain`t bovvered. Link to comment Share on other sites More sharing options...
