madmav2 Posted October 11, 2005 Report Share Posted October 11, 2005 Hi can anyone help please? I have a 2000"w" 1.820v se estate i have just done 3500 miles around europe and i noticed sometime she would run like it was a bit lathargic(poor Throttle responce and sometimes fuel consumption seemed to dip ! i took it into my dealer when i got back and they plugged it in PC and the report said 4 problems 1,Maf air sensor which i have now replaced . 2 was a water tempreature sensor 3 was a camshaft sensor 4 was a manifold pressure change over valve! we have also changed the manifold presure sensor now!! The other two faults have dissapered since clearing the fault sensor. so tonight i got the bonnet up and got the wife to start the car whilst i looked and listened. I could here a noise under the manifold like a clicking noise, when she switched the engine off you can here the clicking noise slow down and stop! then you hear like a quiet Air exhaust noise!!!! i have also tried sucking the vacume pipe wich opens the diaprham on the side of the inlet manifold but nothing happens!!!!!! ok the symptons are!!! as you accelerate from a standstill.as shee climes through 2.5-3000 rpm the car feels like it is holding back!! Pick up speed and the faster you go the slower the engine builds, when you get up to say 8omph and you want to back out of the gas a little to "Cruise" she wont.. so you either back off and car slows down or put your foot down and she struggles on!!! it's just like she is being strangled!!! can anyone help or throw some light on it ! i have an idea its the flap inside the inlet manifold sticking /stuck!!!! has anyone had a similar problem Please help mav Link to comment Share on other sites More sharing options...
mulkbear Posted October 12, 2005 Report Share Posted October 12, 2005 Sounds like the throttle body needs cleaning or replacing get it checked out at your local friendly VW dealer. The Clicking nosie sounds very much like the charcoal filter ckicking.(normal) Link to comment Share on other sites More sharing options...
madmav2 Posted October 12, 2005 Author Report Share Posted October 12, 2005 Thanks mate i will get it checked out! just been out in it again and problem is deffo between 1000Rpm and 2500 RpmĀ¬! Link to comment Share on other sites More sharing options...
