novarallyman Posted October 21, 2005 Report Share Posted October 21, 2005 I have fitted a Nav+ to my A6 and all is working fine. I decided to add a TV tuner as well, but although I am fairly sure my wiring is correct, when I switch to TV, I just get white noise and none of the controls work, any ideas? Link to comment Share on other sites More sharing options...
craigyb Posted October 21, 2005 Report Share Posted October 21, 2005 Did you change the Antenna Amplifers and Diversity switcher for TV & radio ones. The standard ones are radio only. If you didnt change anything, how did you connect the TV to the antennas? Link to comment Share on other sites More sharing options...
novarallyman Posted October 24, 2005 Author Report Share Posted October 24, 2005 I not connected any aerials yet, I had jut connected the tuner to the head unit, so was not expecting to pick up any channels, however I was expecting to be able to try to tune it in, but I can't the controls do not work. Link to comment Share on other sites More sharing options...
craigyb Posted October 24, 2005 Report Share Posted October 24, 2005 Did you connect the can wires? control of the channels etc is sent over can. And what setup do you have? you mention Nav+, is it the RNS-D, CD or RNS-E, DVD version. They both use different tuners. Craig Link to comment Share on other sites More sharing options...
novarallyman Posted October 25, 2005 Author Report Share Posted October 25, 2005 Yes, can wires are connected, if I disconnect just the can wires then it is not possible to switch to TV on the Nav+. Nav+ is a D with the correct tuner ( B model I think ?) Colin Link to comment Share on other sites More sharing options...
craigyb Posted October 25, 2005 Report Share Posted October 25, 2005 Ok, did you code the RNS-D in VAG-COM to say you have a tuner? Craig Link to comment Share on other sites More sharing options...
novarallyman Posted October 25, 2005 Author Report Share Posted October 25, 2005 It appeared to be already set, but I am going to check again in the morning, thanks Colin Link to comment Share on other sites More sharing options...
novarallyman Posted October 26, 2005 Author Report Share Posted October 26, 2005 Craig, I have checked and by Nav+ is not set to know there is a TV Tuner, and what is more, I can not set it, VAG-COM will only let me set it to 0 or 1, not 4, if I enter 4 both the test and save buttons grey out. Any ideas ? COlin Link to comment Share on other sites More sharing options...
craigyb Posted October 26, 2005 Report Share Posted October 26, 2005 Do you have the full version of VAG com and the latest software. 4 = TV and no other options, so needs to be set. Craig Link to comment Share on other sites More sharing options...
novarallyman Posted October 26, 2005 Author Report Share Posted October 26, 2005 Ah, no I don't have a full version, but it does allow me to modify certain settings, and definately lets me set the option to 1 ! Not sure I can justify the price of a licence just to get the TV tuner working! Is there any other way of setting this without the full version of the software ? Thanks Colin Link to comment Share on other sites More sharing options...
craigyb Posted October 26, 2005 Report Share Posted October 26, 2005 I dont know why you cant mod it to 4, seems odd. but without the full version to compare against I cant be sure. Link to comment Share on other sites More sharing options...
novarallyman Posted October 27, 2005 Author Report Share Posted October 27, 2005 I have now tried with a full version of Vag-com and have the same issue, Channel 7 will only let me set it to 1 or 0....any ideas ? Is it possible I need to upgrade the firmware on the NAV+ ? Link to comment Share on other sites More sharing options...
novarallyman Posted October 28, 2005 Author Report Share Posted October 28, 2005 Oh Dear..... Found the software on the Nav+ appeared to be old, so I tried upgrading it, update appears to have gone all the way through, but had a message saying it had an error reading the disc. Now it wont initialise the navigation CD, or allow me to attempt to reinstall the software again. Vag-com can not talk to the controllers for either navigation or the radio....... And on top of that the menus are all in German now.... Is it screwed..... Help Colin Link to comment Share on other sites More sharing options...
kelly24 Posted October 29, 2005 Report Share Posted October 29, 2005 I have an Audi S4 with satelite navigation system with TV function. Some how the TV is muted. I have not got a clue what i might of pressed and there is nothing in the manual to give any clues. I have rang audi dealers and even they dont really know. If anyone has simple solution i would be grateful. Link to comment Share on other sites More sharing options...
novarallyman Posted October 29, 2005 Author Report Share Posted October 29, 2005 OK, it appeared that the Nav+ needed a sleep, I had a look at it this morning and it appeared to finish installing the software ( even though the update disc was no longer in there) and now it is all working as before. I have now been able to set the nav options to 4, however I still have no control of the Tuner. Are all the controls trough the CAN interface? so as long as these 2 are connected all should work ? I have tried swapping the cables over, but then I could not switch to TV, which is why I assummed that I had it connected correctly....but as I have tried 2 tuners I can only assume that the problem is wiring......any further ideas ? Link to comment Share on other sites More sharing options...
craigyb Posted October 29, 2005 Report Share Posted October 29, 2005 Is it set for UK? The audi band is differnet for each country, try going into the TV setup and selecting UK & Ireland. [ QUOTE ] I have an Audi S4 with satelite navigation system with TV function. Some how the TV is muted. I have not got a clue what i might of pressed and there is nothing in the manual to give any clues. I have rang audi dealers and even they dont really know. If anyone has simple solution i would be grateful. [/ QUOTE ] Link to comment Share on other sites More sharing options...
craigyb Posted October 29, 2005 Report Share Posted October 29, 2005 What are the part numbers of the NAV & TV? TV should be 4D0 919 146 B Craig Link to comment Share on other sites More sharing options...
novarallyman Posted October 31, 2005 Author Report Share Posted October 31, 2005 Hi Craig, The Tuner is 4D0 919 146 B and the Nav is 4B0 035 192 HX. Colin Link to comment Share on other sites More sharing options...
novarallyman Posted November 3, 2005 Author Report Share Posted November 3, 2005 Craig, do the part numbers help ? Link to comment Share on other sites More sharing options...
zarkic Posted December 9, 2009 Report Share Posted December 9, 2009 Is it set for UK? The audi band is differnet for each country, try going into the TV setup and selecting UK & Ireland.[ QUOTE ] I have an Audi S4 with satelite navigation system with TV function. Some how the TV is muted. I have not got a clue what i might of pressed and there is nothing in the manual to give any clues. I have rang audi dealers and even they dont really know. If anyone has simple solution i would be grateful. [/ QUOTE ] I dont know why you cant mod it to 4, seems odd. but without the full version to compare against I cant be sure. Hello. I live in Bosnia and poorly speak English. I have a similar problem with audi navi plus. pressing the button 21 does not offer meny so that my tv only displays snow. how to solve the problem? Thanks in advance Link to comment Share on other sites More sharing options...
twofast Posted February 12, 2010 Report Share Posted February 12, 2010 Hi, i have the exact same problem on an Audi S4 -04. The car has navi, cd-changer and tuner. But all i can do is go to the tuner an watch "wihte snow" no changes possible at all... the controls simpy don´t work as they should compared to our audi RS4 with the same navi (RNS-D) Does anyone know what the problem could be?? //PIerre Link to comment Share on other sites More sharing options...
