Tomk Posted October 25, 2005 Report Share Posted October 25, 2005 right vnc just wont work ... it has worked in the past. i run a netgear wirless router and set it up wtih a nat table so ports are closed, has it stoped working cos of an xp update ? just dont know were to start Link to comment Share on other sites More sharing options...
Frodo Posted October 25, 2005 Report Share Posted October 25, 2005 Temporarily turn off the firewall in Windows XP, look under the network interface. Otherwise you could try a telnet on the port that VNC uses through the firewall. You say you have NAT enabled, are the workstations using DHCP or static addresses? Link to comment Share on other sites More sharing options...
skifly Posted October 25, 2005 Report Share Posted October 25, 2005 presume you are using a lappy - if so then you need to make sure that the lappy always gets the same ip. I think i probably have the same router as you and what you can do is set the ip to be reserved (think thats what its called in the router setup). That was the problem with my VNC connection as the router was pointing the port to a non-existent pc. Link to comment Share on other sites More sharing options...
Tomk Posted October 25, 2005 Author Report Share Posted October 25, 2005 they both have static ip's no firewall... it worked before and have even tried to open the ports to ip addresses btu still nothing ! grrr any other Remote software i can try ? Link to comment Share on other sites More sharing options...
skifly Posted October 25, 2005 Report Share Posted October 25, 2005 very odd as i have had vnc running on my home machine for nearly 3 years now without any issues at all besides the usual "user" errors! Link to comment Share on other sites More sharing options...
Gaunty Posted October 25, 2005 Report Share Posted October 25, 2005 Is VNC conflicting with Remote Desktop? Try turning the remote desktop service off. Link to comment Share on other sites More sharing options...
Tomk Posted October 25, 2005 Author Report Share Posted October 25, 2005 yup thats off on all pc's Link to comment Share on other sites More sharing options...
Gaunty Posted October 25, 2005 Report Share Posted October 25, 2005 What else is running on 3389 then? Do netstat -a -b from your command prompt and look at port 3389, here's mine for comparison, I have RDP turned on. <font class="small">Code:</font><hr /><pre>C:\>netstat -a -b TCP prof-farnsworth:3389 prof-farnsworth:0 LISTENING 936 -- unknown component(s) -- C:\WINDOWS\system32\RPCRT4.dll c:\windows\system32\rpcss.dll C:\WINDOWS\system32\svchost.exe C:\WINDOWS\system32\ADVAPI32.dll [svchost.exe] </pre><hr /> Link to comment Share on other sites More sharing options...
