amazak Posted November 24, 2005 Report Share Posted November 24, 2005 hELLO Having issues with my heater, work intermittently. Golf Mk2 16v gti. Any suggestions? Cheers Link to comment Share on other sites More sharing options...
TheEdge Posted November 27, 2005 Report Share Posted November 27, 2005 Hi mate had a golf gti mark 2 1990 (purchased in 2000 58 thousand on clock) heater problems didnt really happen till the following winter 2001 typical just when you need it october to march it packs up, common problem is the heater matrix my mechanic had a look at it found leaves had clogged up and other rubbish blocking the heating cost about £70 to £80 i think atthe time to get sorted thne went wrong again a year later!! another problem could be the idle switch if the car is hesitating alot this could be causing this problem as well hope this helps Link to comment Share on other sites More sharing options...
amazak Posted November 29, 2005 Author Report Share Posted November 29, 2005 Will check it out. Thanks Link to comment Share on other sites More sharing options...
amazak Posted November 29, 2005 Author Report Share Posted November 29, 2005 Where exactly is the heater matrix position, is it below the windscreen/wipers on the left where the air grids on the bonnet are? OR is it under the dash drivers side? Cheers Link to comment Share on other sites More sharing options...
