roberica Posted November 28, 2005 Report Share Posted November 28, 2005 Hi Can anyone tell me how to adjust the camber on my 98 A6 Avant? Thanks OB Link to comment Share on other sites More sharing options...
Edd_W Posted November 29, 2005 Report Share Posted November 29, 2005 There is only very limited adjustment. If it side to side you are after to balance things up then you can loosen and shift the sub-frame. If you are after normal adjustment then all you have is the amount of movement there is on the top mount bolts. You can get adjustable top links made up but they are way to pricey for any normal road car. I suppose if you are keen enough you could make the inner top link mounting bolt hole oval and get a bit of movement there but it will probably screw up the caster and the effective variable king-pin angles. The axis on which the wheel turns is not a true pivot it is a moving axis which is what give it a bit better turn-in but could be easy to screw up. Link to comment Share on other sites More sharing options...
