jock23 Posted January 20, 2006 Report Share Posted January 20, 2006 Need to do my front ones on my mk3 golf tdi and am currently trying to decide whether or not to do it myself or pay about £120-£200 for a garage to do it. Is it relatively easy to do? Do i need to be careful about anything when buying parts or actually doing to change?? Link to comment Share on other sites More sharing options...
Dave Posted January 20, 2006 Report Share Posted January 20, 2006 For the sake of £120 i would get some-one to do them. It will also give you piece of mind. I tried to change over some brakes with a mate of mine and it was not an easy job. We didn't have the right tools (we needed a special tool to seal the brake pipes) and getting the new calipers to fit was tough too! we did it in the end, but we still went to the garage to get it checked! Link to comment Share on other sites More sharing options...
pritesh Posted January 20, 2006 Report Share Posted January 20, 2006 are u just wanting to change the pads or the entire lot? Link to comment Share on other sites More sharing options...
Mk3golfer Posted January 20, 2006 Report Share Posted January 20, 2006 your mk3 pads and discs will be easy, save the 120 and get yourself a haynes manual for about £15! if you have a rough knowledge of the brakes you will be easy but if not just say... Link to comment Share on other sites More sharing options...
asta Posted January 20, 2006 Report Share Posted January 20, 2006 pads only is an easy job. discs a bit more of a job but not too hard. Only problem with discs is getting them off can sometimes be tricky. They may be stuck to the hub or the bolts can be pretty tight. I doubt you are changing the calipers, but even then you are unlikely to need a brake pipe nib thingy - you only need that when you are replacing the brake pipes. just make sure you get the correct pads. bit of a bugger when they give you the wrong ones and you are half way through the job! Link to comment Share on other sites More sharing options...
jock23 Posted January 21, 2006 Author Report Share Posted January 21, 2006 Yeah just changing the pads and discs, not calipers. Struggling to get my alloys off just now anyway, so dont know what am gonna be like with rest of brakes!!! Thats one of the things putting me off, getting all the right pads/discs etc. Got a haynes manual already. Link to comment Share on other sites More sharing options...
R32North Posted January 21, 2006 Report Share Posted January 21, 2006 Just remember rear brakes on VAG cars require a tool to push and turn the piston in at the same time, but fronts don't! Its pretty tricky if you don't have the tool! Link to comment Share on other sites More sharing options...
Stu_UK Posted January 22, 2006 Report Share Posted January 22, 2006 If you don't have the tool to push and turn the piston on the rear brakes, I used a large clamp and a pair of mole grips. Apply a bit of pressure with the clamp and then turn the piston with the mole grips. It takes a bit of time but saves a few quid. Link to comment Share on other sites More sharing options...
