Talex GPS speed cam detector Installations ?
very easy to hard wire in. The cigar lead just needs to be cut to remove the cigarette end then you can add a inline fuse and wire into the car as you have done with the micro roadpilot. If you have a heated or UV screen you may have a few issues as the talex will only work then using the talex mount which will needs situating up next to the rear view mirror. so people don't want the unit that high. Hope this helps....
