Is this clutch or dual mass flywheel problem
banny
Sometimes am having real problems getting into gear, when first pulling away.
Today was at a junction and no way could I get the car in first or second gear, I somehow got it to go into third and that hard.
I went and done some shopping and the car was alot better, could get all gears fine, maybee a little tough to get down the gears.
I have already posted before about vibration and was told this is a VAG problem with the flywheel if you put your foot down too much at low revs in a high gear, so anyway can drive round that no problem.
But not being able to get into gear can be a major problem.
I must add, when car is in gear and in motion, it is no problem to change and also there is no clutch slip at all, even when you boot it.
I should also add car has been chipped.
  • 3 years later...
