How to put in stereo code for Laguna
deanos3
I'm back with my manual.
Switch radio on, the display should read "CODE", then "0000" will appear.
Use the wheel on the back of the remote behind the steering wheel to change the first digit of the 0000 to the first digit in your security code.
Press the "lower key" (looks to me like the end button) on the remote to confirm the digit, and move on to the next.
Repeat until the 4 digits read the same as your code.
When complete, press the "lower key" again until you hear a beep which will validate the code.
  • 4 weeks later...
the lower key being referred to in the manual isn't one of the buttons on the end of the control stalk, they are for the volume, they mean the button on the bottom of the control stalk, & yes the rest of the method you desribed is correct
  • 6 years later...
My Radio just says CODE. IT WONT DO ANYTHING ELSE!!!!!!!!! there are no flashing numbers now, and when they did magically appear, I pressed the button to put in the numbers and it went back to 'CODE' again. What can I do, it's driving me mad!!!
can anyone please help?!
