m9445210 Posted April 14, 2006 Report Share Posted April 14, 2006 so S3 can do that ? i want to try BOSCH Dynamometer but my friend only 2wheel dyna. EIP TUNING STAGE 4 R32 TURBO VIDEO Link to comment Share on other sites More sharing options...
Paul Posted April 14, 2006 Report Share Posted April 14, 2006 Haldex do not recommend it without disconnecting the prop shaft, Especially if the rear wheels are not able to rotate, ie on hard ground. Some people have had it done with no issues, a couple have had it done and needed new haldex's. I personally would not risk it, and have refused 2wd dynos in the past. Link to comment Share on other sites More sharing options...
Dandle Posted April 14, 2006 Report Share Posted April 14, 2006 I believe you have to pull the fuse to the haldex system then you can run the dyno on the front wheels only. Link to comment Share on other sites More sharing options...
Paul Posted April 14, 2006 Report Share Posted April 14, 2006 there are other ways, but its still not recommended. if the rear wheels are not free to rotate, then the prop is still turning in the haldex unit and is creating drag in the oil. drag = heat. Its better if the wheels are free to rotate if they need to, but still not recommended because the great difference in speeds between front and rear. it really is at you own risk. Its not intended to run 2wd on dynos, and why would you want to anyway as the data will be wrong as you have disconnected half the drive train and losses. Link to comment Share on other sites More sharing options...
m9445210 Posted April 18, 2006 Author Report Share Posted April 18, 2006 ask other Forums get some info http://forums.vwvortex.com/zerothread?id=2555853 Link to comment Share on other sites More sharing options...
