vag com
s3ollie
Did you get the cable from a seller called e-cafe?!
Version 311.2n or 409 will work, but you'd need to configure VAG-COM to look at the com port which the USB cable is emulating (you can find this by looking at Ports (Com & Lpt) in Device Manager).
You'll have limited functionallity though without a registered version of VAG-COM (i.e. you'll be able to read fault codes, modify some but not all coding and adaption codes.) 169144-ok.gif
If you have the dual K line, USB cable, then go for the Twin-COM version of VAG-COM.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
