sparky2076 Posted April 19, 2006 Report Share Posted April 19, 2006 my air con lcd display consol has started flahing for a few minutes when i start car all works ok just display,anyone had similar Link to comment Share on other sites More sharing options...
Waitey Posted April 19, 2006 Report Share Posted April 19, 2006 Yep i had same problem on mine, i got the aircon recharged and it stopped doing it. Although it doesnt get as cold as it used to. Probably cause i got it done by local garage who didnt do it properly, you best getting it done at an independant garage or dare i say the stealers. Link to comment Share on other sites More sharing options...
meriafel Posted April 19, 2006 Report Share Posted April 19, 2006 I had the same flashing display a few weeks ago but only on one occasion. A VAGCOM check at Inchcape in Shrewsbury showed that the original battery was below par and showing several faults in the memory which they related to the reduced voltage, which I posted on here on VAGCOM. One of these fault codes related to my air-con. I had to have a new air-con condenser after a badger hit and naturaly had a recharge of gas so I'm not sure whether the new battery or the recharge sorted the problem. My original battery was still showing green in the 'magic eye' and was registering 12.59 volts on a digital meter? Although off the car it still shows 12.60volts and green. What is the state of your battery? It is possible that it is due to low battery voltage but that is purely a guess. See my post on VAGCOM which got no replies! Link to comment Share on other sites More sharing options...
