watteee Posted April 28, 2006 Report Share Posted April 28, 2006 just found out the other day about the LED`s in the vents and they are getting rigged up tomorrow,is there anything else that lies dormant that can be made to work,i have a 2001 B6 tdi 130,i know a lot of manufacturers fit the same wiring loom throughout their range and according to the spec is just plugged in. Link to comment Share on other sites More sharing options...
Avus_Bub Posted April 28, 2006 Report Share Posted April 28, 2006 Roof LED's ? BUB Link to comment Share on other sites More sharing options...
Avus_Bub Posted April 28, 2006 Report Share Posted April 28, 2006 If you're feeling a bit more adventurous how about Rear LED's ? BUB Link to comment Share on other sites More sharing options...
jdearauj Posted May 2, 2006 Report Share Posted May 2, 2006 [ QUOTE ] just found out the other day about the LED`s in the vents and they are getting rigged up tomorrow,is there anything else that lies dormant that can be made to work,i have a 2001 B6 tdi 130,i know a lot of manufacturers fit the same wiring loom throughout their range and according to the spec is just plugged in. [/ QUOTE ] So how do i go about getting this fitted??? Link to comment Share on other sites More sharing options...
watteee Posted May 3, 2006 Author Report Share Posted May 3, 2006 thats the leds in and working,i used a 9 mm drill bit and 2 black rubber grommets to finish the rough edges off,looks superb,cant wait til tonight to see the effect. rear ones are next,not bad for 10 minutes work and £10.16 for the part. Link to comment Share on other sites More sharing options...
jdearauj Posted May 5, 2006 Report Share Posted May 5, 2006 Can somebody please show me the link or let me know how i go about getting the vent LED's installed? Have tried to do a search and can't find anything? Many Thanks Link to comment Share on other sites More sharing options...
watteee Posted May 5, 2006 Author Report Share Posted May 5, 2006 try clicking on the link in the post that avus bub did a few posts b4 this one,its easy. Link to comment Share on other sites More sharing options...
jdearauj Posted May 5, 2006 Report Share Posted May 5, 2006 [ QUOTE ] try clicking on the link in the post that avus bub did a few posts b4 this one,its easy. [/ QUOTE ] Think then i'm getting confused as i thought this was LED's in the air vents and not the LED's in the roof. I have already done the roof LED update. Thanks Link to comment Share on other sites More sharing options...
watteee Posted May 5, 2006 Author Report Share Posted May 5, 2006 Sorry misunderstood you,ive done the vents and the roof leds,its not actually the vents that light up,its the little wheel you adjust to turn the airflow on and off. I put a shoelace in the top slat of the vent and used tweezers to feed it thru the next one down,keep doing this till the lace is out the bottom slat,then pull till the vent comes out.(be careful slats can break easily). once out you will see the cable for the leds,i got my mate who is an auto spark to wire them up as its not as simple as a sidelight feed to each one,they have to be wired in sequence ie feed from sidelight switch to the drivers side vent then to centre vents to the passenger vent then all way back to sidelight switch(something like that). I personally dont think it made a great difference but its free if you know how to do it or someone you know does. All the best of luck. Link to comment Share on other sites More sharing options...
