Rear wiper not working properly.
collease
Mk4 golf GTI 1.8T.
Rear wiper has been working fine all through the winter but came to use it yesterday and it stopped half way through the full motion. I have checked the fuse and its fine all the lights work and nothing else had gone wrong. I tried just flicking it on and off to see if it had just got stuck but nope even after cleaning the blade and the window still no joy. This morning i managed to get it to complete its wipe but again it still does not work. Is it likely to be a loose connection somewhere or something more worrying.
hi, I had exactly same symptoms with mine last winter. Its caused by worn/siezed internals inside motor. Mine started playin up cos i tried to wipe rear screen still full of ice ! not recommended ....Replacing motor is only solution and fitting is a quick easy fix. I got my reconditioned motor for £40 from my local vw/audi salvage yard and took just 30 mins to remove rear panel and hook up. You just need to be careful when removing motor from glass! i used my haynes manual as reference/tips.Good luck
Is it the motor the arm ? The arm can stay still while the spindle turns - if this is the case you can remove the arm, clean up the spindle splines & screw the arm back down - or decide it is time for a polo/touran wiper upgrade !
