youngri Posted May 8, 2006 Report Share Posted May 8, 2006 Anyone else had problems with the opensky roof? Wife's car roof no longer works. When button is pushed the roof will move maybe an inch and then make a rapid clicking noise (like clutch slipping or gear teeth jumping). Looking at the motor, I can see the shaft turning when this happens but no movement of the roof. I'd appreciate any advice, but it looks like motor and/or gearbox will need replacing. Has anyone had to do this and if so is it straightforward or a definite dealer job? With the manual override crank handle, I was still able to fully close the roof. - Thanks Link to comment Share on other sites More sharing options...
brownswood Posted May 15, 2006 Report Share Posted May 15, 2006 try the a2oc forums someone i know recently had a problem with his (paddys) www.a2oc.net good luck as its well expensive to replace.. Link to comment Share on other sites More sharing options...
