Fergy Posted May 9, 2006 Report Share Posted May 9, 2006 A3 Sportback front windows rattle. Is it worth putting vaseline on top of the glass? Link to comment Share on other sites More sharing options...
AirMax Posted May 10, 2006 Report Share Posted May 10, 2006 surley your just going to get ugly grease all over you windows :\ Link to comment Share on other sites More sharing options...
Guest slittley Posted May 11, 2006 Report Share Posted May 11, 2006 Are you sure it's the window rattling and not something else? Rattles in cars can be very deceiving. They can often be coming from somewhere quite different from where they seem to be coming from. Does it stop if you apply pressure to the window with your hand? Link to comment Share on other sites More sharing options...
A3Floyd Posted May 11, 2006 Report Share Posted May 11, 2006 dont put vaseline on them! If they're rattling, then there's nothing wrong with either the channels or the window rubbers. They have a felt covering to stop the window rubbing which can produce a noise similar to a rattle. if the felt is buggered in some way (excuse the technical term) then this could be the problem. Link to comment Share on other sites More sharing options...
Fergy Posted May 11, 2006 Author Report Share Posted May 11, 2006 too feckin late. Vaseline applied. Guess I need to remove Link to comment Share on other sites More sharing options...
