kite Posted May 9, 2006 Report Share Posted May 9, 2006 Hi all My daughters A3 has been to the dealers today. They set the 2 button door lock and auto lock at 15mph, they told me that you can't make the alarm beep when it locks, I had this set on my A4 !!! Is this true !! Link to comment Share on other sites More sharing options...
Paul Posted May 9, 2006 Report Share Posted May 9, 2006 New A3 or Old? Old A3/S3 can be done for sure.(with vagcom) dealer should know how to do it with their equipment. New A3, not sure never done it. Irrc I think i read somewhere that the B7 A4 doesnt have the locking beep, so it could be its a function thats been lost on the new version. Link to comment Share on other sites More sharing options...
kite Posted May 9, 2006 Author Report Share Posted May 9, 2006 A4 is B6. A3 is I think 8P Link to comment Share on other sites More sharing options...
Paul Posted May 9, 2006 Report Share Posted May 9, 2006 New A3 then. Im not sure if it has this feature. Can anyone confirm? Link to comment Share on other sites More sharing options...
peterb Posted May 10, 2006 Report Share Posted May 10, 2006 Bring it to the next Windsor meet - we'll have a try. Link to comment Share on other sites More sharing options...
craigyb Posted May 10, 2006 Report Share Posted May 10, 2006 A3 it can be done with the long coding helper. As long as your VAG lead supports canbus. Link to comment Share on other sites More sharing options...
craigyb Posted May 10, 2006 Report Share Posted May 10, 2006 On the A3 8P Select 46 (Comfort System) Long Coding -> Function 07 Byte 06 Bit 7 Adaptation of Horn Confirmation locked So toggling this bit should activate/deactivate the horn on lock Link to comment Share on other sites More sharing options...
kite Posted May 11, 2006 Author Report Share Posted May 11, 2006 Cheers fella's. See you at Windsor Peter, thanks Link to comment Share on other sites More sharing options...
craigyb Posted May 11, 2006 Report Share Posted May 11, 2006 Just done an RNS-E and BT telephone installation in an A3 8P, after which I coded the door lock above 15kph and alarm beep on locking. All worked perfectly. Although on the long coding helper it actually said "Adaptation of Horn Confirmation blocked" not locked and that was ticked, I unticked it and the alarm beeped on locking. Craig [ QUOTE ] On the A3 8P Select 46 (Comfort System) Long Coding -> Function 07 Byte 06 Bit 7 Adaptation of Horn Confirmation locked So toggling this bit should activate/deactivate the horn on lock [/ QUOTE ] Link to comment Share on other sites More sharing options...
kite Posted May 12, 2006 Author Report Share Posted May 12, 2006 Thanks, I'll get it done at next Windsor meet ! Link to comment Share on other sites More sharing options...
craigyb Posted May 12, 2006 Report Share Posted May 12, 2006 Just tried recoding a brand new 06 A3 with horn honk, guess what, it didn't work. Maybe I did something wrong, but I used the same procdedure as yesterday, toggle off the Blocked bit and tested, no bleep. Maybe it is a feature of the new A3 that it is fully disabled. Craig Link to comment Share on other sites More sharing options...
peterb Posted May 31, 2006 Report Share Posted May 31, 2006 An update on this: We unset Byte 06, Bit 7 and the horn didn't beep. I looked at the next byte (05 or 07, I can't remember), and it had a couple of bits for horn on locking - one for remote and one for key locking. Set the 'remote' one and the horn started working. Anyway, thanks for the original info, Craig, it helped us to get there. Link to comment Share on other sites More sharing options...
peterb Posted June 1, 2006 Report Share Posted June 1, 2006 [ QUOTE ] I looked at the next byte (05 or 07, I can't remember), and it had a couple of bits for horn on locking - one for remote and one for key locking. [/ QUOTE ] According to openobd, it's byte 07, bits 1 & 3 for key & remote. Link to comment Share on other sites More sharing options...
craigyb Posted June 1, 2006 Report Share Posted June 1, 2006 Glad you got it sorted Link to comment Share on other sites More sharing options...
kite Posted June 1, 2006 Author Report Share Posted June 1, 2006 Peter did a great job. My daughter is over the moon. dealer told her it could'nt be done Link to comment Share on other sites More sharing options...
Rustynuts Posted June 2, 2006 Report Share Posted June 2, 2006 (dealer couldn't be arsed....) Link to comment Share on other sites More sharing options...
peterb Posted June 2, 2006 Report Share Posted June 2, 2006 [ QUOTE ] My daughter is over the moon. [/ QUOTE ] I always do my best to keep the ladies happy! Link to comment Share on other sites More sharing options...
kite Posted June 2, 2006 Author Report Share Posted June 2, 2006 Now time to research the power steering. She should thank you in person ! Link to comment Share on other sites More sharing options...
peterb Posted June 2, 2006 Report Share Posted June 2, 2006 [ QUOTE ] Now time to research the power steering. [/ QUOTE ] I have looked at the information on OpenOBD and cannot see anything about 'tuning' the behaviour of the steering. [ QUOTE ] She should thank you in person ! [/ QUOTE ] I did think of suggesting this, but didn't wish to cause offence! Link to comment Share on other sites More sharing options...
UweRoss Posted June 3, 2006 Report Share Posted June 3, 2006 On all the Mk.5-based cars with computerized electronic steering assist there's an adaptation channel that specifies which of up to 15 different steering boost "maps" are used by the system. Unfortunately, the maps vary wildy between different cars and different control modules. Also which map is "optimal" is a very subjective thing. So there can be a bit of trial and error involved in tweaking this. But it's quite easy to revert it to stock, so no harm to it either. -Uwe- Link to comment Share on other sites More sharing options...
peterb Posted June 3, 2006 Report Share Posted June 3, 2006 [ QUOTE ] On all the Mk.5-based cars with computerized electronic steering assist there's an adaptation channel that specifies which of up to 15 different steering boost "maps" are used by the system. [/ QUOTE ] Any clues as to which channel it would be on a 2005/2006 A3? Link to comment Share on other sites More sharing options...
kite Posted June 3, 2006 Author Report Share Posted June 3, 2006 Any help with channels would be great. The car is 03/04 model Link to comment Share on other sites More sharing options...
Paul Posted June 3, 2006 Report Share Posted June 3, 2006 Controller 44 - Steering asssist Theres some posts about it HERE. Link to comment Share on other sites More sharing options...
kite Posted June 3, 2006 Author Report Share Posted June 3, 2006 thanks Paul ! Link to comment Share on other sites More sharing options...
