Showboat Posted May 15, 2006 Report Share Posted May 15, 2006 T reg Golf 1.9TDI oil warning light comes on then car loses power and cuts out! No oil leak visible. Car able to start up again once stopped and drives ok. Has happened twice, both times on motorway. Any suggestions please? Link to comment Share on other sites More sharing options...
Rustynuts Posted May 15, 2006 Report Share Posted May 15, 2006 I suspect the oil light is coming on because the engine has stopped, rather than the light coming on then the engine stopping. I also suspect a relay 109 faulty, though I don't know for certain where it is in your car. It'll be on a relay board rather than the fuse board. Cost a few quid from the dealer, DIY replacement, and it should cure it. Change it before it fails and won't let you start up again. It's a common fault. ps. the relay might be upside down and look like 601 rather than 109. Link to comment Share on other sites More sharing options...
benjie Posted May 15, 2006 Report Share Posted May 15, 2006 109 109 109 109 109 109! I thought that before I even read the thread!! Link to comment Share on other sites More sharing options...
Showboat Posted May 16, 2006 Author Report Share Posted May 16, 2006 109 replaced! Fingers crossed! Thanks for your help guys! Link to comment Share on other sites More sharing options...
