BOSKO Posted May 15, 2006 Report Share Posted May 15, 2006 Hellow! Can somebody please give me some usefull pointers which tyres I should put on A8 4.2 quattro. I'll buy my Audi untill end of summer and I don't want any surprises when I buy it. I must prepare my budget So what should I put on? (Good Year Eagle F1, Dunlop SP MAX...) I'll probably put on 19"s. I have another question for someone who ownes tiptronic gearbox. I've never driven an automatic or tiptronic...Can someone please explain me what do those 2nd, 3rd and 4th gear means and in which gear do I drive if I want to get out the most POWER or for economical drive...? TNX for all your help Link to comment Share on other sites More sharing options...
Teacake Posted May 15, 2006 Report Share Posted May 15, 2006 I always use Eagle F1s, they transformed my S8, are epic in the wet and have a decent life, and wouldn't ever touch Dunlops. However, if ever there was an appropriate time to use the disclaimer "Your mileage may vary", this is it... Link to comment Share on other sites More sharing options...
Ska Posted May 15, 2006 Report Share Posted May 15, 2006 I'm using 245/40 19 Pirelli P zero's saved someones life once and boy was I glad. Just stick the shifter into D and the car will do the rest, 2,3 and 4 are realy if your on a gradient and you select the gear that gives the best torque to climb it. Tiptronic at any time move the shifter into the shorter gate and it becomes a sequensial forward to shift up and backwards to shift down Link to comment Share on other sites More sharing options...
Muppet_man Posted May 15, 2006 Report Share Posted May 15, 2006 I've had Pirelli P zeros also and found them to be excellent. However I've just had some Avons fitted and they are a big suprise. Roadholding and grip seem to be the same, but noise ride and lack of road steer is fabulous! They were a good price as well. Double bonus. Link to comment Share on other sites More sharing options...
BOSKO Posted May 15, 2006 Author Report Share Posted May 15, 2006 Thanks Ska but I still don't know when to use 2nd? or 3rd or 4th? please explain those:) Link to comment Share on other sites More sharing options...
crasher Posted May 16, 2006 Report Share Posted May 16, 2006 Tyres: I'm currently running Michelin Pilot SPort SP2's as these were my recal freebies Gears: Can't speak for all, however, i have tended to use the tip-mode to hold it in 2,3 or 4 if i want controlled decent on a hill, or to stop it hunting when i'm traversing the hills around malvern (where i live). Nothing worse than taking a tight hairpin and flooring it out only to have to wait for the gearbox to catch up. Link to comment Share on other sites More sharing options...
Wilfred Posted May 16, 2006 Report Share Posted May 16, 2006 Tiptronic. Use when pressing on along a twisty back road. 4,3,2 1. Idea is to use when on steep descent. Never had that with mine. I only ever use 4 on when I'm running cruise control on a particularly steep section of fast motorway/dual carriageway to stop the auto box hunting between 4 and 5 in full auto mode. As above. Stick it in D and you cant go wrong. Link to comment Share on other sites More sharing options...
nikw Posted May 16, 2006 Report Share Posted May 16, 2006 I have used Avon ZZ3s and Dunlop SP9000s. The Avons are slightly cheaper and give a better ride with reduced noise; the Dunlops were, I believe, the original fitment the cars were supplied with when new. Selecting 2, 3 or 4 sets the highest gear the gearbox can use, e.g. selecting 3 will allow the box to use 1, 2 & 3 but not 4 or 5. Occasionally useful for climbing & descending hills, max speed runs (select 4) or perhaps when towing when 4 would prevent the box from hunting between 4 & 5. I've never used them, instead going straight into Tiptronic mode for full control. Link to comment Share on other sites More sharing options...
Jimmer01225 Posted May 16, 2006 Report Share Posted May 16, 2006 Has anyone every used these ? http://www.mytyres.co.uk It seems like there could be some good deals there even after the fitting costs. Link to comment Share on other sites More sharing options...
nikw Posted May 16, 2006 Report Share Posted May 16, 2006 Do check your local supplier though - my local Just Tyres was able to undercut MyTyres' price for a pair of Avon ZZ3s. Unlike the monkeys in blue overalls whose employer's name is misspelt, I have always found JT willing to negotiate. Link to comment Share on other sites More sharing options...
spencerbruntlett Posted May 16, 2006 Report Share Posted May 16, 2006 For what its worth my 20" rims came with Sumitomo tyres fitted (http://www.sumitomotire.com)and although pretty cheap they are excellent. Bit of web searching show that they have close connections with Goodyear which might explain it. They are yet to let me down and I would have them again Link to comment Share on other sites More sharing options...
gapthree Posted May 17, 2006 Report Share Posted May 17, 2006 I ran my Bridgstones for 30K but in the wet the ABS came on a lot. Switched to Eagle F1's and they are excellent. Had them for 5k so don't know what the wear rate is yet. Link to comment Share on other sites More sharing options...
Mort Posted May 22, 2006 Report Share Posted May 22, 2006 I use Pirelli P Zeros - good all round tyre - wet and dry . Reasonable price.. Link to comment Share on other sites More sharing options...
AnArtist1 Posted May 23, 2006 Report Share Posted May 23, 2006 I've used: The crap tyres that came with the car... began with an 'M' Eagle F1s - Brilliant Continental Sport Contact 2 - Not as good as I expected Pirelli P Zeros - much better than I expected. I will go Eagle F1s next time (if they do 20's).... I think?! Link to comment Share on other sites More sharing options...
Will22 Posted May 23, 2006 Report Share Posted May 23, 2006 @ AnArtist, do you have any idea how many S8's were made in Avus silver with red leather, your car is excatly the same as mine. Link to comment Share on other sites More sharing options...
FuntimeFrankie Posted May 23, 2006 Report Share Posted May 23, 2006 [ QUOTE ] I've used: The crap tyres that came with the car... began with an 'M' Eagle F1s - Brilliant Continental Sport Contact 2 - Not as good as I expected Pirelli P Zeros - much better than I expected. I will go Eagle F1s next time (if they do 20's).... I think?! [/ QUOTE ] I've got these, why are the others better? Curious, as I've nothing to compare them with Link to comment Share on other sites More sharing options...
A8_Tony Posted May 24, 2006 Report Share Posted May 24, 2006 I run Cooper/Avon Zeons in a 245/40 20R fitting, and they're fabulous. I had some cheaper tyres on there when i bought the rims, but these shredded after about 7k miles, I've had the Avons on now for 17k miles and there's still plenty of tread on them......even after a stint around the track Link to comment Share on other sites More sharing options...
AnArtist1 Posted May 24, 2006 Report Share Posted May 24, 2006 I had Contis 2s on another car once upon a time, it made it grip like a limpet! But on the QSport the grip and 'seat of the pants feeling' didn't feel as strong as with the Eagle F1s. As for the S8 and the P Zeros they are fine. Only physics is my enemy now!! Also, I don't know how many Avus silver and RED special 'pimp' editions were made, sorry. Link to comment Share on other sites More sharing options...
