Hudster Posted May 22, 2006 Report Share Posted May 22, 2006 This must have been posted before but I had a play on search and could only find threads on the A3 60k service, so here goes... My Golf IV 1.8T is on 58k and due it's service, VW quoted me £169 which is fine. It's still under warranty and I'm happy collecting my VW stamps for now. They also suggested I needed the cam belt and brake fluid changed at the following prices Cam belt £315 Brakes £68 So I have 2 questions really: 1 - what's the real opinion on when you should change the cam belt? I've seen everything from 60k to 120k on this forum and I dont want to blow £300 if it's really not necessary yet 2 - £68 for brake fluid? seems a lot but I am relatively inexperienced with this stuff - shall I just get the local garage to do this? thanks in advance Link to comment Share on other sites More sharing options...
Oli Posted May 22, 2006 Report Share Posted May 22, 2006 There is no recommended time for a belt change on a VW, but I would suggest getting it done at around 60,000 miles. We are an independent, obviously miles away from you, but how are prices compare to main dealers are as follows; Your service would cost approx £110, The cambelt change would be approx £220 and the brake fluid change is approx £35. thats quite a saving!!!! If you want to keep up the VW stamp in your book, which on a car that age doesn't make any difference, then get it serviced at VW, then get any extra's done at a specialist. We always use genuine parts on any vehicle we work on Link to comment Share on other sites More sharing options...
