Hopsta Posted May 23, 2006 Report Share Posted May 23, 2006 Audi Tonka Toy gives 4 beeps on startup, flat battery of somekind? Link to comment Share on other sites More sharing options...
crasher Posted May 23, 2006 Report Share Posted May 23, 2006 My S8 does this. Audi have said that its the Alarm backup battery that is failing and will need replacing. Maybe the same on yours. Link to comment Share on other sites More sharing options...
Hopsta Posted May 23, 2006 Author Report Share Posted May 23, 2006 this the complete unit or just the battery? Link to comment Share on other sites More sharing options...
Paul Posted May 23, 2006 Report Share Posted May 23, 2006 its battery back up in the alarm related iirc. Not sure what the solution is/was, but there is post after post about it on www.TT-forum.co.uk Link to comment Share on other sites More sharing options...
Hopsta Posted May 26, 2006 Author Report Share Posted May 26, 2006 Twas indeed to Alarm unit, £198 to be changed at the stealer, not bad for 3 weeks out of warranty and no good will from Audi Link to comment Share on other sites More sharing options...
crasher Posted May 26, 2006 Report Share Posted May 26, 2006 Ah, then that is the sort of expense i will face when i get my car back then Link to comment Share on other sites More sharing options...
Gren Posted May 26, 2006 Report Share Posted May 26, 2006 Mine's been doing this for around 6 months now. £150 was the quote for the new battery to be fitted! Didnt take them up on the offer. Not that bothered - the alarm still works but can now be disconnected from the battery. The immobiliser and steering lock will make sure it doesnt move though. Link to comment Share on other sites More sharing options...
slol Posted May 27, 2006 Report Share Posted May 27, 2006 Had this on an a4 1.8t sport,problem was caused by the door switch not thinking the door was closed,so overnight the battery voltage was lower than it should be(which i believe is what triggers the beeps)with the door problem solved and the cars battery recharged overnight,it was cured.So try just charging your battery and see if this cures the problem,as batteries tend to loose charge after a certain age even if there are no other probs,hth Link to comment Share on other sites More sharing options...
Kell Posted June 6, 2006 Report Share Posted June 6, 2006 Must admit that mine started doing this a while back (as you'll read if you click the link above). However, I still thikn it's linked to the fact that my main battery was losing charge. Once my trickle charger was fitted, I had no further problems. Link to comment Share on other sites More sharing options...
