kashifm123 Posted May 24, 2006 Report Share Posted May 24, 2006 while I was driving I receive this message on screen (Engine Workshop)and the coile was blinking as well. Checked with the VW tools software and the error was: 16955 P0571 Cruise/Brake Switch (A) Circ Malfunctio Please advise Link to comment Share on other sites More sharing options...
daz60932 Posted May 24, 2006 Report Share Posted May 24, 2006 Check your brake lights, if both bulbs have gone replace these and the brake light switch(located above/on the brake pedal) Brake light switch Link to comment Share on other sites More sharing options...
kashifm123 Posted May 25, 2006 Author Report Share Posted May 25, 2006 I checked the break lights its gone, and cruise control is not working as well, so if I change the break swith will cruise control work as well. Regards Daz60932 Kashif Link to comment Share on other sites More sharing options...
Rustynuts Posted May 25, 2006 Report Share Posted May 25, 2006 Your cruise control isn't working because it thinks you have your foot on the brakes. When you change the switch for a fully functional one, it'll work again. Link to comment Share on other sites More sharing options...
daz60932 Posted May 25, 2006 Report Share Posted May 25, 2006 /\ What he said Link to comment Share on other sites More sharing options...
Wobby Posted May 28, 2006 Report Share Posted May 28, 2006 On mine the switch was Switch F on VAG COM. I changed mine like an idiot! To find i never looked at the obvious first! A FUSE had blown Your code us malfunction, dont think mine was. I would check everything else first, connections, fuses for both cruise and brakes (mine doesn't have cruise) Just a thought good luck EDIT!....I think mine fused when i plugged a trailer lights plug in Link to comment Share on other sites More sharing options...
