w1how Posted May 26, 2006 Report Share Posted May 26, 2006 I have a tt coupe 225 53 reg and sometimes it is hard to change into first gear,even at standstill.Is this normal or is there a problem??? Link to comment Share on other sites More sharing options...
Gren Posted May 26, 2006 Report Share Posted May 26, 2006 My gearbox took around 10k to loosen up but was never really that bad. If anything reverse was the issue more than the other gears. Sometimes a bit awkward when cold but sounds like there could be an issue with yours. Link to comment Share on other sites More sharing options...
wcs_80 Posted May 27, 2006 Report Share Posted May 27, 2006 [ QUOTE ] I have a tt coupe 225 53 reg and sometimes it is hard to change into first gear,even at standstill.Is this normal or is there a problem??? [/ QUOTE ] It may need adjustment.........you can check this by: Putting it into 2nd gear, then hold the gear stick to the left, if it is correctly adjusted, when you let go, it should spring about 1/8 of an inch back. Link to comment Share on other sites More sharing options...
