Will22 Posted May 27, 2006 Report Share Posted May 27, 2006 If anyonr knows where I can get one please help, I'm not paying the steelers nearly £1000 Link to comment Share on other sites More sharing options...
Dadstoys Posted May 27, 2006 Report Share Posted May 27, 2006 Is this like a towbar - but for putting your feet on ?? Link to comment Share on other sites More sharing options...
Will22 Posted May 27, 2006 Author Report Share Posted May 27, 2006 The very same, you must have be very smart Link to comment Share on other sites More sharing options...
Dadstoys Posted May 27, 2006 Report Share Posted May 27, 2006 Life passes by so much easier with a smile. Have you tried ebay for the towbar ? You can now put a wanted advert on there - under the " want it now " section or something of a similar name. Toe bars will be under the jewellery section !! Link to comment Share on other sites More sharing options...
Will22 Posted May 27, 2006 Author Report Share Posted May 27, 2006 Sometimes things pass me by too fast ToWbars for A/S8's are like rockinghorse sh!t to get The ones on eBay are all steel bars, not a good thing to have bolted onto an alloy body Link to comment Share on other sites More sharing options...
Nelson_R32 Posted May 27, 2006 Report Share Posted May 27, 2006 Pressumably you just want a bar and not the electics? I'll see what I can do on an OEM bar for you on Tuesday Link to comment Share on other sites More sharing options...
Will22 Posted May 27, 2006 Author Report Share Posted May 27, 2006 Nelson, it would be great if I got the electics as well, cheers Link to comment Share on other sites More sharing options...
Mort Posted May 30, 2006 Report Share Posted May 30, 2006 Try HERE Earlier Thread HERE He supplied mine which I had fitted at a local garage. Make sure they take anti corrosion measures. Link to comment Share on other sites More sharing options...
Paul Posted May 30, 2006 Report Share Posted May 30, 2006 Anygood? read first post in thread.. [ QUOTE ] Finally, does anybody want a GDW approved towbar with detachable ball which fits the all the D2 A8/S8 (up to 2002). I had just fitted it to my S8 (in preparation for taking the caravan to Le Mans next month) so it is mint (installed but never used). The kit includes all the instructions, bolts/washers and wiring for twin electrics including the necessary isolation relays (so you dont upset the ECU/system)with the wiring loom cut to the correct length for easy fitting. I fitted it myself - you have to remove the rear bumper but it is an easy job and I now know exactly how to do it. I would like £275, which compares very favourably with Audi stealers who want about £1200+ including fitting. I will put it in the for sale section shortly - sadly it will not fit the new car. [/ QUOTE ] Link to comment Share on other sites More sharing options...
Will22 Posted May 30, 2006 Author Report Share Posted May 30, 2006 OK thanks for all the help lads but I bought the towbar from RichardW last night. Cheers again for all the help Will Link to comment Share on other sites More sharing options...
