mb Posted May 30, 2006 Report Share Posted May 30, 2006 Hi Scanned my friends G4 which is showing the "emissions workshop" light & got the following - Address 01: Engine Part No: 06A 906 018 EF Component: 2.0l R4/2V MOTR HS V04 Coding: 00031 Shop #: WSC 00028 4 Faults Found: 16496 - Intake Air Temp. Sensor (G42): Signal too Low P0112 - 35-00 - - 16556 - Fuel Trim; Bank 1: System Too Rich P0172 - 35-00 - - 16518 - Oxygen (Lambda) Sensor B1 S1: No Activity P0134 - 35-10 - - - Intermittent 17536 - Fuel Trim; Bank 1 (Mult): System too Lean P1128 - 35-10 - - - Intermittent Readiness: 0010 0001 The car is running out & cuts out - do you think it is worth disconnecting the MAF or do these point to a more specific fault ? Thansk Martin Link to comment Share on other sites More sharing options...
slol Posted May 30, 2006 Report Share Posted May 30, 2006 Martin,i have had the p1128 code on a 1.8t which was definitely the maf. Try changing that and clear the others and see what comes back. Link to comment Share on other sites More sharing options...
mb Posted May 30, 2006 Author Report Share Posted May 30, 2006 Thanks for the advice - was leaning towards the MAF as they are "known suspects" Cheers Martin Link to comment Share on other sites More sharing options...
UweRoss Posted May 30, 2006 Report Share Posted May 30, 2006 This link may be helpful: http://www.ross-tech.com/vag-com/cars/fuel-trim.html -Uwe- Link to comment Share on other sites More sharing options...
mb Posted May 31, 2006 Author Report Share Posted May 31, 2006 Thanks Uwe - that's a great link Cheers Martin Link to comment Share on other sites More sharing options...
