harminder Posted May 30, 2006 Report Share Posted May 30, 2006 Most times I press the clutch down to change gear I can hear a whooooosh noise coming from around the engine bay.. I dont think it can be the turbo as this seems to happen at lows revs as well as high revs (from 1500rpm onwards)... Also ever since I have had the car the clutch has always had a very high biting point and often when you pull off from a standing start the car seems to vibrate as the clutch is released! Any ideas if this is all related (car has done 60k).. Link to comment Share on other sites More sharing options...
Hudster Posted June 9, 2006 Report Share Posted June 9, 2006 my golf did exactly that (not the biting point bit - you're on your own there) but everytime I dropped the clutch there was this whooshing noise even when going at slow speeds to cut a very long story short, it turned out to be the turbo pressure valve which was a quick replacement job by VW (you could probably do it yourself if you know how), I think the part was around £70 + labour Link to comment Share on other sites More sharing options...
harminder Posted June 12, 2006 Author Report Share Posted June 12, 2006 [ QUOTE ] my golf did exactly that (not the biting point bit - you're on your own there) but everytime I dropped the clutch there was this whooshing noise even when going at slow speeds to cut a very long story short, it turned out to be the turbo pressure valve which was a quick replacement job by VW (you could probably do it yourself if you know how), I think the part was around £70 + labour [/ QUOTE ] Thanks Hudster! Anyone know if its worth changing the turbo pressure valve quickly or shall I wait for it to get a little worse? Dont feel any loss of power but then again I dont want it to damage anything else! Link to comment Share on other sites More sharing options...
Hudster Posted June 13, 2006 Report Share Posted June 13, 2006 mine was quiet when I got it, then got louder and louder over 6 months had no (noticable) impact on power, and one of my mates told me I should leave it as it sounded cool not dangerous as far as I'm aware as it just makes the turbo slightly less efficient, but you might as well fix it now you know what it is if you have access to a VAGCOM I can show you the readout my car gave at the time so you can compare and double check Link to comment Share on other sites More sharing options...
