SPLiiX Posted May 31, 2006 Report Share Posted May 31, 2006 I downloaded music to a disc and tried it in the car but it did not work in the car?? Do I need a different type of Disc?? What am I doing wrong. I'm not "into" this as you can tell....... Link to comment Share on other sites More sharing options...
petsy Posted May 31, 2006 Report Share Posted May 31, 2006 It could simply be your head unit is not able to read the format which your music is burnt to disk. Link to comment Share on other sites More sharing options...
j2027059 Posted May 31, 2006 Report Share Posted May 31, 2006 did you put mp3's on the disc? might be the head unit not reading them... although saying that it could be thousands of things i'd check you write a audio disc (should only get about 15ish songs, an mp3 disc will get 100's) and also if its a cd-r (re writable) it might not work as some steroes and i assume head units struggle to read them. good luck! Link to comment Share on other sites More sharing options...
SPLiiX Posted May 31, 2006 Author Report Share Posted May 31, 2006 Thanks GUys! Yep, only about 15 songs on it. I thought that everybody would do this and I was not doing something right???? Link to comment Share on other sites More sharing options...
peterb Posted May 31, 2006 Report Share Posted May 31, 2006 An audio format CD-R ought to work (CD-RW almost certainly won't). I always used CD-R in my Audi 6-disc changer. Does the disc play on your home CD player? Are you playing this on the Symphony? What happens when you attempt to play it in the car? What identification is printed on the CD? What software are you using to write the disc? Are you sure that you've used audio (.wav - wave) format? Link to comment Share on other sites More sharing options...
