GTi Setups for 17 and 18 monzas
JonGTI
You do it or the garage ,it is a switch located in the consol near the gear lever or ash tray,turn the ignition on and press and hold the tyre monitor button until an audible confirmation sounds job done.....this must be done when changing any ammont of wheels,what ever the tyre pressures in the tyres are ie 2.4bar this then sets to this,if ONE drops by 3psi they will sound a bleep,and show a symbol indicated on the dash.Or if you are going to be fully loaded and need to increase the tyres pressures to the next setting carry out this procedure.... beerchug.gif
The tyre monitor uses data from the ABS sensors to check the speed of rotation and rolling circumference of the individual wheels.
