kp090 Posted July 7, 2006 Author Report Share Posted July 7, 2006 MO found the elite tyres place. lookin at there picure they use HUNTER machine for alignment... i think they cant do camber angles and stuff becuase the garage i went to before had that. Link to comment Share on other sites More sharing options...
Mo-S3 Posted July 7, 2006 Report Share Posted July 7, 2006 Give them a ring and see what they say. Might be able to do some adjustment if it needs it. You do know that there is no camber adjustment possibe on the rear unless adjustable tiebars have been fitted which you wont have as you dont have lowered suspension. The front camber is very easy to do anyway; 3 nuts on the lower arm allows the suspension a few degrees of camber adjusment. They will easily be able to adjust the toe angle(also known as the thrust angle) on the front. The rear however is more of a pain to do but can be done. Do you know if they completey removed the rear trailing arm when the spring was replaced? Link to comment Share on other sites More sharing options...
kp090 Posted July 7, 2006 Author Report Share Posted July 7, 2006 i have no idea mate, all i know is that they gave me a bit of the coil which snapped off and said the whole spring needs to be replaced. so i got the springs and they replaced it. all i know is that wen i took it ages ago before the springs were replaced for alignment the people had a hunter machine and said camber angles cant be done as they aint got equipment for it so need to go to audi to get it done. and while driving the car it doesnt seem like secure driving fast on anormal road. motorway seems a bit more secure but still risky when you go proepr fast Link to comment Share on other sites More sharing options...
loafer27 Posted July 7, 2006 Report Share Posted July 7, 2006 theres a tyre place just down the road from aston greens in slough they did 4 wheel alignment on mine for 60 quid or something Link to comment Share on other sites More sharing options...
kp090 Posted July 7, 2006 Author Report Share Posted July 7, 2006 Loafer can you remember what the place was called? was it protyre? or feltham tyres? was car did u have an S3? Link to comment Share on other sites More sharing options...
loafer27 Posted July 9, 2006 Report Share Posted July 9, 2006 it was protyre they have a 4 wheel alignment machine it was on a A3 3.2 but still Quattro so similar set up to S3 still have the printout here showing caster /camber/toe for fronts and camber /toe /thrust angle for rears . Link to comment Share on other sites More sharing options...
kp090 Posted July 9, 2006 Author Report Share Posted July 9, 2006 cheers loafer, yea thats the garage i first went to, they told me they cant do it for my car because they hadnt got the correct equipment or something to adjust the camber angles?? Ive booked myself into APS, hours drive but every1 been sayin its suppose to be a really good service Link to comment Share on other sites More sharing options...
