9969 Posted July 26, 2006 Report Share Posted July 26, 2006 I was wondering if anyone could help ! I have a '99 1.8 T and was replacing some of the vacuum pipes that control the turbo system on my car. (The pipe was about 6-8 mm diameter and split) I have tried to get the metal "O" shaped rings that crimp to make an air tight seal - but can't seem to find a supplier any where , and the Dealer will charge me an arm and a leg (per clamp) Anyone know of a good supplier ? Link to comment Share on other sites More sharing options...
Rustynuts Posted July 26, 2006 Report Share Posted July 26, 2006 These sort of things? Link to comment Share on other sites More sharing options...
9969 Posted July 26, 2006 Author Report Share Posted July 26, 2006 Not quite mate ! It's a small ring (like for your finger) that goes around the vacuum pipe - which you then push onto the metal pipe that you want to connect it to Crimp with a specila pair of pliers either side Link to comment Share on other sites More sharing options...
9969 Posted July 26, 2006 Author Report Share Posted July 26, 2006 I've drawn one - plan view (badly) perhaps this may jog someone's memory ! Link to comment Share on other sites More sharing options...
philipdayton Posted July 26, 2006 Report Share Posted July 26, 2006 Won't jubilee clips do the trick? Link to comment Share on other sites More sharing options...
Rustynuts Posted July 26, 2006 Report Share Posted July 26, 2006 Funnily enough, that's what was on that link when I posted it. Dunno what's happened. Link to comment Share on other sites More sharing options...
9969 Posted July 26, 2006 Author Report Share Posted July 26, 2006 Sorry mate - all I got was "Swivel Foot Spindles" I can't seem to get any jubilee clips small enough either ! Link to comment Share on other sites More sharing options...
Rustynuts Posted July 26, 2006 Report Share Posted July 26, 2006 Local motor factors (Partco / Andrew Page etc.) should sell them? Hose crimps are what they're called. Link to comment Share on other sites More sharing options...
9969 Posted July 26, 2006 Author Report Share Posted July 26, 2006 Off to Partco tomorrow then ! Thanks - I'll see what they've got Link to comment Share on other sites More sharing options...
SteNova Posted July 27, 2006 Report Share Posted July 27, 2006 your after fuel hose clips Link to comment Share on other sites More sharing options...
9969 Posted July 27, 2006 Author Report Share Posted July 27, 2006 Yes - if they are small enough to take a pipe about 8mm in diameter Link to comment Share on other sites More sharing options...
SteNova Posted July 27, 2006 Report Share Posted July 27, 2006 yup.. i use them on high boost cars for all the vaccum/boost pipes Link to comment Share on other sites More sharing options...
