Motormouth Posted July 30, 2006 Report Share Posted July 30, 2006 I pushed the stalk to wash my rear screen this morning, I heard the motor go but no water was sprayed out (I did have water in there). Looked in my rear view mirror and could see the water coming into the car I took the trim off and could see the platic bit the connects the pipe that feeds the water to the spray bit had cracked and could not connect back on, recon it must of been heat as strange part to fail. Does anyone know if the plastic joint bit can be replaced on its own or would the whole pipe which I assume runs from the front of the car have to be replaced (which would be a bastard). I tried masking it up which fixes it a bit but still have water comming in. This is an 02 A3 but I assume the setup parts is pretty simular across all Audi's Thanks Quote Link to comment Share on other sites More sharing options...
4RingsDH Posted July 30, 2006 Report Share Posted July 30, 2006 Fairly common problem on A3's. I would usually cut off the plastic connector and use a bit of rubber tubing in its place (vacuum hose). I would insert the existing plastic washer tube into the rubber tube and then connect the other end of the rubber tube onto the rear washer jet, use small cable ties to ensure connections. 3-4 cms of rubber tubing is enough. Regards Quote Link to comment Share on other sites More sharing options...
Motormouth Posted July 30, 2006 Author Report Share Posted July 30, 2006 Thanks should of though of that myself :0) Quote Link to comment Share on other sites More sharing options...
Paul Posted July 30, 2006 Report Share Posted July 30, 2006 www.vagparts.com sell a repair kit. navigate to their shop. Audi -> A3 upto 2003 -> Exterior -> Rear wiper repair kit Quote Link to comment Share on other sites More sharing options...
Motormouth Posted August 3, 2006 Author Report Share Posted August 3, 2006 Cheers its doesnt have the bit i need though, its the plastic bit that hangs off the water feeder pipe. Im going to try the vacuum hose route suggested by 4RingsDH, does anyone know when I can buy this from ? Seem them on ebay but dont have an account yet, only other places seem to sell it it in min 25meter lengths, I want around 4cm but will settle for a meter Quote Link to comment Share on other sites More sharing options...
