Paul Posted August 11, 2006 Report Share Posted August 11, 2006 Possibly one for Uwe or Sebastian I have the Hex-USB+CAN lead. Is there any documentation for what the different colours of status LED refer to? Also how does the built in vagsaver work? (should i come across it) [ QUOTE ] instantly alerts the user if either the K/K1 line or the L/K2 line is shorted to Ground or Vbatt. [/ QUOTE ] Does this pop up a warning? or is it related to earlier question of the LED I used the search box on your site, and browsed/searched the latest manual, and drew a blank on both. Many thanks. Link to comment Share on other sites More sharing options...
Sebastian Posted August 12, 2006 Report Share Posted August 12, 2006 On your HEX Interface the LED status green after having it plugged in shows everything is OK. If the LED blinks red after plugging in, you either have a short to ground or short to plus. If you use Options > Test the dialog will tell you what's up in detail. While communicating the LED changes continously between green and red, this tells you that there is a communication going on. Link to comment Share on other sites More sharing options...
Paul Posted August 12, 2006 Author Report Share Posted August 12, 2006 Cheers Sebastian. I had slow alternating green/red when talking to the engine. I thought it may have to be amber, but im guessing thats when logging because of the data rate and the change between green/red being quicker. Link to comment Share on other sites More sharing options...
Sebastian Posted August 12, 2006 Report Share Posted August 12, 2006 There was a change in the LED actuation, so it's correct that it was amber/green up to the last version of VAG-COM. Link to comment Share on other sites More sharing options...
Paul Posted August 12, 2006 Author Report Share Posted August 12, 2006 Ah that explains it! I am indeed running 607.2. ps. Sent you that information you requested Link to comment Share on other sites More sharing options...
