simon999 Posted August 14, 2006 Report Share Posted August 14, 2006 Hi, Has anyone encountered a problem where when you turn the volume up on the concert cd/radio that it goes down rather than up initially, particularly when there's a soft bit on the cd? If so, is this common and should I get the unit replaced under the warranty? Cheers in advance, simon. Link to comment Share on other sites More sharing options...
rball Posted August 14, 2006 Report Share Posted August 14, 2006 I had that on my old S3! Gets worse when it was cold I found. Think all that can be done is to swap the HU. Never bothered to change mine and only sold the car recently Link to comment Share on other sites More sharing options...
blix Posted August 14, 2006 Report Share Posted August 14, 2006 common fault on the concert radio audi will do an exchange unit for about £200.also think if you search this forum their is a post metioning a firm that can repair it Link to comment Share on other sites More sharing options...
sufu Posted August 14, 2006 Report Share Posted August 14, 2006 Heh mine was doing this last winter, but i never got round to fixing it as in warmer weather it doesn't do it... better get it done before the cold weather kicks in Link to comment Share on other sites More sharing options...
s4sjefen Posted August 15, 2006 Report Share Posted August 15, 2006 My car also have this problem! It is an eprom inside, and IC whitch is "out of memory". Because everytime u turn the volum it is stored in a way in this IC! Jørn Link to comment Share on other sites More sharing options...
JayBeeS3 Posted August 15, 2006 Report Share Posted August 15, 2006 had my radio repaired (via the dealer) because the only other alternative was to buy a new one (EUR 1.000). apparently switching an old radio for a refurbed one was not possible here in Cloggyland. Repair took a bit long (8 weeks) but only costed EUR 160. It was the Eprom chip and like others I only had 2 options for the volume: either full or nothing at all (quite annoying). Also I had a cracking noise from one of the rear speakers. This also was solved by the new chip (I assume because the cracking sound is now gone). Link to comment Share on other sites More sharing options...
