007forever Posted August 18, 2006 Report Share Posted August 18, 2006 HI, Guys: 1st post here, I am from Syd Aus. Thinking of buying a GTi in Sep. So, have been lurking a bit in here...and you guys are awesome! Now, first question: what's the temperature of the stock xenon bulb? I's assume it's something like 4000K, can I put in a 8000K one? Can it handle? thanks Link to comment Share on other sites More sharing options...
RedRobin Posted August 18, 2006 Report Share Posted August 18, 2006 A Warm Welcome to you Mr Syd Aus Lurker! I don't know the answer to your question but I'm curious as to why you would want to fit what surely must be an even hotter bulb. Also, doing so would trash your warranty on those expensive but excellent Xenons. Link to comment Share on other sites More sharing options...
nhs Posted August 18, 2006 Report Share Posted August 18, 2006 A warm welcome indeed! The K refers to the "light temperature", as in "red hot" (which is a much low temperature that halogens/xenons). The issue as to what the GTI unit can take in the way of a bulb relates to the current and power demands of the bulb you are intending to put into the unit. If the bulb has the same power characteristics as the OEM bulb then there shouldn't be a problem. If it is different, then you risk problems with the VW units - currently about A$1700 a set from here You should ask the specialist bulb supplier if they will warrant their bulbs against causing damage in the VW units before you buy or get your VW dealership to provide and install and include them in the warranty Link to comment Share on other sites More sharing options...
mikemod Posted August 18, 2006 Report Share Posted August 18, 2006 I think the standard Xenon is 4500K There is no problem fitting higher colour temperature bulbs, they are usually rated at 35W, but as you head up to the purple end of the light spectrum, ie at 8000k+, the visible light output is greatly reduced. Good for shows and cruising, not much good on a dark country lane. Link to comment Share on other sites More sharing options...
Snoopy Posted August 18, 2006 Report Share Posted August 18, 2006 I cannot remember but i know this has been talked about alot in the states on there forums @ http://www.golfmkv.com/forums/index.php? and http://www.vwvortex.com/index.html Link to comment Share on other sites More sharing options...
007forever Posted August 20, 2006 Author Report Share Posted August 20, 2006 Thanks heaps for your quick response guys! From my own understanding, the unit itself should be able to handle 8000K, though wasn't sure about warranty. And, yeah, agree with @mikemod at 4500K the visibility is the greatest, so am just thinking somwhere around 6000K -- both lookin good and practical. And, thanks @Snoopy, i will check out the yanky forums Link to comment Share on other sites More sharing options...
