RichardT Posted August 19, 2006 Report Share Posted August 19, 2006 Not in the way I would hope though, I have a 05 140 tdi sportback. When i start it up and pull away after it has been stood for a while, the car shudders, almost like the clutch is slipping or something like that. It is more noticeable when the car is on an incline and therefore under load. When the car is warm it goes away. The dealer has checked it out but couldnt find anything. Any ideas, or anyone had the same thing. Rich. Link to comment Share on other sites More sharing options...
Jools Posted August 19, 2006 Report Share Posted August 19, 2006 Had the same thing on an A4 tdi. But also did the same thing when slowing down, ended up being a faulty valve in the DSG gearbox replaced under warranty. Low and behold it has started again and it is now a week out of warranty. Link to comment Share on other sites More sharing options...
S3ENVY Posted August 19, 2006 Report Share Posted August 19, 2006 You've got another 7 days let to renew the warranty then!!! Link to comment Share on other sites More sharing options...
Cupramax Posted August 19, 2006 Report Share Posted August 19, 2006 [ QUOTE ] Had the same thing on an A4 tdi. But also did the same thing when slowing down, ended up being a faulty valve in the DSG gearbox replaced under warranty. [/ QUOTE ] A4's dont have DSG gearboxes... Link to comment Share on other sites More sharing options...
iceman2002_uk Posted August 19, 2006 Report Share Posted August 19, 2006 yeah A4's are multitronic Link to comment Share on other sites More sharing options...
MRT Posted August 19, 2006 Report Share Posted August 19, 2006 [ QUOTE ] yeah A4's are multitronic [/ QUOTE ] My A4 2.5TDi Sline 55 reg is a 6 speed manual gearbox its only in the last couple/three of months that Audi have removed the manual gearbox from the site Link to comment Share on other sites More sharing options...
iceman2002_uk Posted August 20, 2006 Report Share Posted August 20, 2006 I'm reliably informed by a well known motoring organisation that Audi's are now equipped with whats called a Dual-Mass Flywheel, where the springs are no longer contained in the clutch plate but in the actual flywheel itself. Apparently these flywheels can warp slightly and make the flywheel vibrate occasionally causing clutch judder, however if the speed sensor on the flywheel for the engine speed cant read the speed correctly for the vibration, like when the engine is under load, it retards the timing and causes a misfire. ....sound familiar??? Link to comment Share on other sites More sharing options...
