dazr32 Posted August 19, 2006 Report Share Posted August 19, 2006 hello people just a question about the haldex oil, at what mileage should it be changed and also what about the filter, should i get that done at the same time, has anyone had this done, if so how much did it cost and is it a diy job or leave it to the professionals. cheers Link to comment Share on other sites More sharing options...
Dan32 Posted August 19, 2006 Report Share Posted August 19, 2006 Oil is changed at 20k and can't remember filter interval but think its 40k. I had filter and oil changed when I had the Haldex PP fitted. Probably worth getting the filter done at same time as oil. Believe its easy enough DIY but its fiddly from what I've read. Probably about an hour for pro to do it. Link to comment Share on other sites More sharing options...
dazr32 Posted August 19, 2006 Author Report Share Posted August 19, 2006 cheers dan i may enquire about oil type and if any special syringe is needed to drain/fill the diff/coupling. Link to comment Share on other sites More sharing options...
bmx Posted August 20, 2006 Report Share Posted August 20, 2006 it takes about 20 minutes to do the oil and filter.(oil £10 filter £20) the oil change is a matter of squirting the fluid in, you use a normal skeleton gun. a special vag spanner (£30 from the dealer)is needed to change the filter. the modshack sell a tool to do it also. Link to comment Share on other sites More sharing options...
bmx Posted August 20, 2006 Report Share Posted August 20, 2006 heres a how to guide, its a very simple job. haldex oil and filter guide Link to comment Share on other sites More sharing options...
bmx Posted August 20, 2006 Report Share Posted August 20, 2006 modshack haldex tool here modshack shop for haldex tool Link to comment Share on other sites More sharing options...
hotdog Posted August 20, 2006 Report Share Posted August 20, 2006 Ere, I had the oil and filter done at 20k and it cost me about £45 all in. Didn't think that was bad really. Link to comment Share on other sites More sharing options...
Skidmark Posted August 20, 2006 Report Share Posted August 20, 2006 [ QUOTE ] cheers dan i may enquire about oil type and if any special syringe is needed to drain/fill the diff/coupling. [/ QUOTE ] Just done my own for the 1st time Oil (comes in a cartrige) & filter from VW [£35 approx] Tools from Laser [via halfords] £24.50 ( a filter spanner & 5mm key for the drain plug as a kit [no. 3938]) Used a mastic gun thingy to push the oil in..... ....you will need a lot of ground clearance to get the gun vertical under the car, if you are not using a lift [!] cheers Link to comment Share on other sites More sharing options...
Royston8 Posted August 21, 2006 Report Share Posted August 21, 2006 Guys I've just bought an 04 R32 & it's on 24k miles. Can you tell me what the Haldex is & why it needs to be done? From the service history I can't see if the Haldex change has been done at 20k miles. Sorry for the (newbie)questions Thanks Link to comment Share on other sites More sharing options...
UKLooney Posted August 21, 2006 Report Share Posted August 21, 2006 Hi, the haldex is the 4wd controller which determines how the power is distributed between the front and rear wheels. It operates utilising hydraulics and needs its oil changed every 20k to keep it working efficently Link to comment Share on other sites More sharing options...
Royston8 Posted August 21, 2006 Report Share Posted August 21, 2006 [ QUOTE ] Hi, the haldex is the 4wd controller which determines how the power is distributed between the front and rear wheels. It operates utilising hydraulics and needs its oil changed every 20k to keep it working efficently [/ QUOTE ] Thanks Link to comment Share on other sites More sharing options...
dazr32 Posted August 21, 2006 Author Report Share Posted August 21, 2006 thanks for the replys people i may have a go at it but if it is only going to save me a tenner (hotdog) then i may as well let the stealers do it. by the way hotdog had the cruise done, the techy did it spot on, just bored going down the motorway now Link to comment Share on other sites More sharing options...
hotdog Posted August 21, 2006 Report Share Posted August 21, 2006 [ QUOTE ] by the way hotdog had the cruise done, the techy did it spot on, just bored going down the motorway now [/ QUOTE ] Did you set to the speed I suggested to test it worked OK Link to comment Share on other sites More sharing options...
dazr32 Posted August 21, 2006 Author Report Share Posted August 21, 2006 yes mate but had a bit of a hard time steering round the granny but thankfully the lights were on green at the bottom of the high street. Link to comment Share on other sites More sharing options...
