PaulW25 Posted September 20, 2006 Report Share Posted September 20, 2006 Hello all, Tried posting in the A4 forum, but no replies so thought it may be worth a try here, as this engine is fitted to more than just the A4... My car is now 3 years old (31,000 miles), so put into Audi for a few final warranty items to be carried out. Mentioned again (first mentioned on the service 4 months ago, but was told all was as it should be) that I thought the gear selection between 1st and 2nd was very notchy, and also 2nd and 3rd (although not as bad). Also think I can feel a very slight judder first thing in the morning, but it is only slight, and may be all in my head. I picked up the car, with the majority of the faults sorted, plus a few scratches (foc!!) to the gear surround done whilst fitting a new head unit .... it really does annoy me why don't they come clean and admit when they've done something wrong, rather than me having to spot it later on. Anyway, they have told me that they will order a new flywheel and clutch under warranty. Has anyone else had this problem and work carried out, and my main question being "DID IT ACTUALLY FIX THE PROBLEM?" I really don't want the car stripped down for all this work if it isn't necessary (I've worked in the trade in the past, and it worries me when I see the number of bolts and fittings left over after a job like this. Thank you. Link to comment Share on other sites More sharing options...
kite Posted September 20, 2006 Report Share Posted September 20, 2006 I had my box changed twice under warranty. I thought the chage from 1st to 2nd was bad, felt like a sticky syncro. I demo'ed a new model while mine was being fixed and thought the new one was as bad. My conclusion is audi manual box fitted to these cars are slow and notchy whatever the dealers do. ps you only get a new box if its less than 3k miles over that you get a recon, that what the service manager told me Link to comment Share on other sites More sharing options...
Atomic Posted September 20, 2006 Report Share Posted September 20, 2006 If it's any consolation I had a E220 (Current shape) from new with a 6 speed box and big box problems! In the first winter from cold I could not get it into reverse (Kinda harsh when you have to reverse out of your garage at 6.00am!) without a lot of grief including stopping/starting the engine, selecting first/second then reverse in pretty much random order until it worked. Being new I took it to the local MB garage who initally claimed there was nothing wrong (turned out on the first occation it was parked in the workshop overnight!) and on the second occation returned the car claiming 'Yes it is a bit notchy, it's a feature of the manual gearbox - you should have got an auto!" - You can imagine my response to the survey I got a few weeks later... Link to comment Share on other sites More sharing options...
cruiser647 Posted September 20, 2006 Report Share Posted September 20, 2006 [ QUOTE ] If it's any consolation I had a E220 (Current shape) from new with a 6 speed box and big box problems! [/ QUOTE ] I was about to say - you bought a manual Merc!?? Link to comment Share on other sites More sharing options...
Atomic Posted September 20, 2006 Report Share Posted September 20, 2006 Yup, I got a manual I love 6 speeds Link to comment Share on other sites More sharing options...
ribena Posted September 21, 2006 Report Share Posted September 21, 2006 paul - hi I had the same thought on getting mine and asked the dealer to check it out they replied there was nothing wrong and have got used to it, but still think its notchy and sometimes have to conciously slow the change to make it smooth i do find the box very low geared and think the torque of the 2.5 would have been better suited to a 5 speed ?? simon Link to comment Share on other sites More sharing options...
PaulW25 Posted September 21, 2006 Author Report Share Posted September 21, 2006 This concurs with what I've been told in the past by the Audi dealership. I also seem to remember reading an article in the past about the engine mounts being quite soft, and that this combined with the relatively short gearing of the 6 speed, is why the problem is sometimes visible on this model. Still not sure whether to have the work done or not .... think I'll try to arrange a test drive in a similar model to compare the gear change and then make a decision after that. Thanks for all your help. Link to comment Share on other sites More sharing options...
paul130TDI Posted September 21, 2006 Report Share Posted September 21, 2006 If its any help, I had the very same problems and complaints with my 2005 2.0TDI S-Line (12,000 miles). From delivery I felt the clutch was very coarse and gearbox was notchy. After numerous returns, they admitted the gearbox was notchier than it should be. The solution was to change the oil to higher graded lower viscosity gearbox oil used in a TT. Initially I felt it especially notchy in 1-4th and fine in 5-6th, while the oil change did help, I’m not convinced how long the solution will last as the oil begins to degrade. As for the clutch, again they admitted it was coarse and changed the flywheel and clutch assy. The loan car they leant me was an identical car with 1500miles. While the clutch was not as bad as my own it was still coarse. When I picked my own up with the clutch changed, initially it was completely different and very smooth. About 100-200 miles later much the same as the loan car, but not as bad as it was previously. The notchy gear change and clutch seems to be another “feature” of the A4, to add to the list of others – Noise from power steering when manovering (Audi response was they know it’s a problem and Audi are aware of it but have no solution, but don’t worry its not a safety issue) Hesitation and stammering when lightly accelerating Rough idle when taking out of gear approaching traffic lights Excessive smoke when starting or accelerating (acknowledged others had mentioned the same) Lazy starter symptoms, especially when cold have to hold the starter on for second after engine has already started. 3 foot of cable trailing the ground (turned out to be previous owner towbar wiring which Audi just cut the wires and left them in) I know I am being picky, but expect an Audi to live up to its promise of quality and reliability, I had an A3 previously and in 4 yrs driving never had a single complaint, yet within 3 mths of owning this one have had it back 6+ times. Link to comment Share on other sites More sharing options...
VTEC_Killer Posted September 21, 2006 Report Share Posted September 21, 2006 I seem to have the same problem with my 1.9TDi (2004) I find, on occasions, from 2nd to 3rd it 'slips' and on a couple of occasions it doesn't engage in 1st - I have to put it in 2nd and then back up into 1st. The car is still under warranty so going to get it checked out on Monday - the dealership said they'll need to take it for a spin. I'll let you know how I get on but I've got a funny feeling they'll say 'it seems fine to me' Sheraz Link to comment Share on other sites More sharing options...
Atomic Posted September 21, 2006 Report Share Posted September 21, 2006 Sheesh, really makes u want to buy an Audi Diesel manual :| Link to comment Share on other sites More sharing options...
kite Posted September 21, 2006 Report Share Posted September 21, 2006 Link to comment Share on other sites More sharing options...
Biffa Posted September 24, 2006 Report Share Posted September 24, 2006 The 6 speed on my TDi allroad is fine Link to comment Share on other sites More sharing options...
JimLoskot Posted September 25, 2006 Report Share Posted September 25, 2006 I have a problem on my 2.5tdi Quattro, when pulling away in 1st gear from standstill whilst turning a corner there is some judder through the car. this only happens when pulling away with the wheels turned and is fine when pulling away straight ahead. Is this due to the quattro? mine is 6 speed btw any ideas please before I go back to the dealers. thanks Link to comment Share on other sites More sharing options...
Atomic Posted September 25, 2006 Report Share Posted September 25, 2006 Sounds like the front CV's. Does it do it turning left or right only? Link to comment Share on other sites More sharing options...
JimLoskot Posted September 25, 2006 Report Share Posted September 25, 2006 Both i think. It does it hot or cold but only when pulling away in first and turning at the same time Link to comment Share on other sites More sharing options...
Atomic Posted September 26, 2006 Report Share Posted September 26, 2006 How old is the car? I'd still guess CV. Can you tell if it's comming from the left or right hand side of the car? Heres a link from audipages what shows the A8 CV joints if it helps: Link Link to comment Share on other sites More sharing options...
JimLoskot Posted September 26, 2006 Report Share Posted September 26, 2006 Thanks Atomic, my car is an 03 plate and has done 49k. Think I'll be going to the stealers next week for them to have a proper look at it Link to comment Share on other sites More sharing options...
chriswhgrant Posted October 6, 2006 Report Share Posted October 6, 2006 Hi there, This is my first post and have read with interest your problems with the manual six speed boxes. I've got a 2004 A6 2.4 with the six speed box and sometimes have difficulty in engaging 1st. I understood from reviews in the press that the gearbox was notchy anyway although didn't expect any trouble selecting 1st!! I owned a A4 Avant 1.8T previously and had no problems at all probably due to the fact it was a 5 speed. The only thing that needed attention on that was a failed boot locking mechanism and a rattle in the dash. To date I've had various rattles rectified, a camshaft sensor replaced, alloy wheel hubs replaced and a squeeky clutch pedal lubricated (which drove me nuts). Think I'll mention this when its next booked in for a service. Have any of you experienced problems engaging 1st gear? Cheers Link to comment Share on other sites More sharing options...
TDiAvant Posted October 6, 2006 Report Share Posted October 6, 2006 My old man's got an A4 2.5 TDi Quattro, the gear changes and pulling away are fine. The car has just under 100k on the clock. Link to comment Share on other sites More sharing options...
PaulW25 Posted October 9, 2006 Author Report Share Posted October 9, 2006 Car was dropped of at the dealership today, so will report on the outcome in a couple of days. Link to comment Share on other sites More sharing options...
JimLoskot Posted October 9, 2006 Report Share Posted October 9, 2006 Would be intrested to hear how you got on Link to comment Share on other sites More sharing options...
PaulW25 Posted October 17, 2006 Author Report Share Posted October 17, 2006 Update... Well, the car was dropped of last Monday to have the clutch and flywheel replaced, plus a couple of other warranty issues. In and out in a couple of minutes and left in a nice new courtesy car. Received a call Tuesday afternoon requesting to keep the car a further day as a couple of addition clips needed ordering to cure an annoying squeak with the drivers lumber support. This was no problem, and sure enough got a call early Wednesday morning to say all the work was done. My wife collected the car and drove it home (reporting it was now much nicer to drive). Took the car for a test run myself and there is a definite improvement. The gear change, whilst I would never describe as silky smooth is much, much better. Previously I had been beginning to think it was all in my head. I do think the car has also taken a little getting used too .... guess it's the combination of short gearing and large amounts of torque from the TDi engine. Overall I'm now happy with the cars gear change's. Link to comment Share on other sites More sharing options...
JimLoskot Posted October 17, 2006 Report Share Posted October 17, 2006 Have just booked mine in, going in next friday. They want £10 for a courtesy car now. I was pretty disgusted tbh. They said it was something to do with the insurance company, load of rubish IMO Link to comment Share on other sites More sharing options...
Tunbridge Posted October 20, 2006 Report Share Posted October 20, 2006 [ QUOTE ] Have just booked mine in, going in next friday. They want £10 for a courtesy car now. I was pretty disgusted tbh. They said it was something to do with the insurance company, load of rubish IMO [/ QUOTE ] Which dealer was that? I recently had a courtesy from Teesside Audi and there was no charge, although the excess was £1000 Good thing I didn't crash it! I think I'd be heading for another dealer if I was you... Link to comment Share on other sites More sharing options...
JimLoskot Posted October 21, 2006 Report Share Posted October 21, 2006 think I will have a look for the next nearest dealer. 1st time I've heard of a charge for a courtesy car. Thanks Tunbridge Link to comment Share on other sites More sharing options...
