petewxm Posted October 16, 2006 Report Share Posted October 16, 2006 Hi I recently had an oil change in my Bora 1.9tdi pd130 and have noticed that the garage that changed the oil have over filled it by about 1/4 of a litre. Will this damage my CAT or engine. Or am I worring for nothing, cause its just a small amount. Or should I drain the additional amount out? Thanks for any advice Pete Link to comment Share on other sites More sharing options...
Dave Posted October 16, 2006 Report Share Posted October 16, 2006 It could damage your cats if you start burning off excess. How do you know they've overfilled it?.. make sure you take your oil dip stick reading when the car is on a level surface and the engine is warm but not hot. Leave it about 20 minutes after turning off. Wipe stick and then re-insert and see what the level is. If it's a big overfill then i would drain some off. Link to comment Share on other sites More sharing options...
petewxm Posted October 16, 2006 Author Report Share Posted October 16, 2006 Hi Dave, Thanks for the speedy reply, I would say the oil level is about a centermeter about the max mark. I will check again later with the enigine warm and on a flat surface. The thing that made me check is that I bought the oil myself and asked a garge to use it, It was a 5 litre tub, it came back with about 250mls, and I read somewhere that the bora holds about 4.5 litres. It looks as if I`ll be draining some oil tonight after work Pete Link to comment Share on other sites More sharing options...
jeepman Posted October 18, 2006 Report Share Posted October 18, 2006 The same thing happened when mine was service by VW had to go back to have some drained as was buring oil and if left would have destroyed Cat. as well as looking naff! Oil level is critical on TDi's. John Link to comment Share on other sites More sharing options...
Wobby Posted October 18, 2006 Report Share Posted October 18, 2006 [ QUOTE ] Oil level is critical on TDi's. [/ QUOTE ] Can someone explain how it been slightly over full makes it burn oil? I have bought Petrol engines that have been over filled, they burn oil but only after the valve stem seals have been damaged. Once the seals are replaced they stopped burning oil!! I know over filling damages the CAT, but why? From burning the oil? May as well ask the question seem as i dont know the answer Link to comment Share on other sites More sharing options...
Rustynuts Posted October 18, 2006 Report Share Posted October 18, 2006 Too much oil will possibly get forced out through the crank case vent as oil vapour when it gets warm. This goes straight into the air intake, and then goes through the burn process. It gunks up all the intake and other such stuff. Link to comment Share on other sites More sharing options...
Wobby Posted October 19, 2006 Report Share Posted October 19, 2006 Thanks, didn't know that Link to comment Share on other sites More sharing options...
