robpink Posted January 7, 2007 Report Share Posted January 7, 2007 after wet weather n/s headlight lens has condensation along the bottom 2 inches or so(not enough for water to collect inside),this disappears after a day or 2, anything to worry about?? Link to comment Share on other sites More sharing options...
MrAvant Posted January 7, 2007 Report Share Posted January 7, 2007 I would take it to the stealer to replace the headlight. Link to comment Share on other sites More sharing options...
UBM Posted January 7, 2007 Report Share Posted January 7, 2007 Leave the engine running and the lights on full beam. The heat will dry them out. There are ventilation holes to let water vapur out on the headlight unit. Link to comment Share on other sites More sharing options...
SamD Posted January 7, 2007 Report Share Posted January 7, 2007 Typically the dealer will tell you to do what UBM has said, and if it dries out in 45 minutes or so it is normal. If it doesn't clear after doing this then they might replace it Link to comment Share on other sites More sharing options...
kenny_boon Posted January 7, 2007 Report Share Posted January 7, 2007 as long as its just misting it will go away as UBM says. its normal and not a problem. if you get water beads/drops then this will be replaced under warranty Link to comment Share on other sites More sharing options...
CabGirl Posted January 7, 2007 Report Share Posted January 7, 2007 Both of my fronts get condensation if it's cold. They're clear by the morning. Link to comment Share on other sites More sharing options...
UBM Posted January 7, 2007 Report Share Posted January 7, 2007 [ QUOTE ] Both of my fronts get condensation if it's cold. They're clear by the morning. [/ QUOTE ] Are you admitting your split personality CG? Link to comment Share on other sites More sharing options...
robpink Posted January 7, 2007 Author Report Share Posted January 7, 2007 thanks chaps, will try the full beam dry-out thing next time Link to comment Share on other sites More sharing options...
