kicking sounds!
Vagabond
In my MKiv ive left the head unit standard but have changed all four speakers and have had an amp wired up to the head unit to power them as as in standard trim it doesn't cut it, ive also got another amp that powers the sub in the boot.
The sound is much better but set me back about £800, but RS32 should be along soon to explain what he runs as is is just awesome notworthy.gif and spent double what i did.
Strangely enough, I did the opposite of JimmyP. In my MKIV all I changed was the head unit (for a Sony MP3/DVD playing unit). The sound is soooooo much better even with the standard speakers.
b0b
Me too and also added a sub (inc amp). You'll find that by changing the stock head unit with its maximum wattage of 2 makes a huge difference as the stock speakers aren't actually that bad 169144-ok.gif
the MkIV standard speakers are infinitely better than in the MkV imho.
I run the following :
Pioneer AVIC-HD1BT headunit - it has a decent parametric EQ with very nice ability to adjust everything.
JL Audio 300/4 Amp
JL Audio 653CSi front components (6.5", 4" and 1")
JL Audio 650CS rear components (6.5" and 1")
Dynamat Extreme in all doors
The whole setup looks completely standard OEM other than the headunit.
I've had to back off the Amp levels after testing it out as it's made me feel physically sick from the sheer volume it will go to without distorting.
