Vagabond Posted January 20, 2007 Report Share Posted January 20, 2007 What can i do to improve the stereo Abba just dont sound as good as they used to....can you hear the drums fernando? Link to comment Share on other sites More sharing options...
BrakeSnake Posted January 20, 2007 Report Share Posted January 20, 2007 Turn it off, find a tunnel and open the window... Think Rs has had his changed and amped, send him a pm... Link to comment Share on other sites More sharing options...
jimmyp Posted January 21, 2007 Report Share Posted January 21, 2007 In my MKiv ive left the head unit standard but have changed all four speakers and have had an amp wired up to the head unit to power them as as in standard trim it doesn't cut it, ive also got another amp that powers the sub in the boot. The sound is much better but set me back about £800, but RS32 should be along soon to explain what he runs as is is just awesome and spent double what i did. Link to comment Share on other sites More sharing options...
BigMeanBob Posted January 21, 2007 Report Share Posted January 21, 2007 Strangely enough, I did the opposite of JimmyP. In my MKIV all I changed was the head unit (for a Sony MP3/DVD playing unit). The sound is soooooo much better even with the standard speakers. b0b Link to comment Share on other sites More sharing options...
Oatz Posted January 21, 2007 Report Share Posted January 21, 2007 [ QUOTE ] Strangely enough, I did the opposite of JimmyP. In my MKIV all I changed was the head unit (for a Sony MP3/DVD playing unit). The sound is soooooo much better even with the standard speakers. b0b [/ QUOTE ] Me too and also added a sub (inc amp). You'll find that by changing the stock head unit with its maximum wattage of 2 makes a huge difference as the stock speakers aren't actually that bad Link to comment Share on other sites More sharing options...
rs32 Posted January 21, 2007 Report Share Posted January 21, 2007 the MkIV standard speakers are infinitely better than in the MkV imho. I run the following : Pioneer AVIC-HD1BT headunit - it has a decent parametric EQ with very nice ability to adjust everything. JL Audio 300/4 Amp JL Audio 653CSi front components (6.5", 4" and 1") JL Audio 650CS rear components (6.5" and 1") Dynamat Extreme in all doors The whole setup looks completely standard OEM other than the headunit. I've had to back off the Amp levels after testing it out as it's made me feel physically sick from the sheer volume it will go to without distorting. However it sounds crystal-clear, and thumps like a good 'un Link to comment Share on other sites More sharing options...
Vagabond Posted January 21, 2007 Author Report Share Posted January 21, 2007 cheers guys. The thing is, i've got sat nav, so i'm stuffed. I wont be able to change the head unit. Link to comment Share on other sites More sharing options...
rs32 Posted January 21, 2007 Report Share Posted January 21, 2007 the cheapest option I can suggest is sticking Dynamat in all the doors. This certainly can't make things worse and will not be wasted if you upgrade the whole system. Do it - I know mhlj83 has already and he seems very pleased. Link to comment Share on other sites More sharing options...
Vagabond Posted January 21, 2007 Author Report Share Posted January 21, 2007 Hmmm, i'll have to look into an alternative headunit with nav then. I'll deffo see about the Dynamat as i've got a decent shop just down the road from here called Sound master. The guy is totally switched on. Link to comment Share on other sites More sharing options...
