weedavey Posted March 2, 2007 Report Share Posted March 2, 2007 Hmmmm. I'll have to keep an eye on that. When it happened I was using Tescos fuel. I do add a fuel conditioneer though PD5, which is fantastic for fuel economy and emissions. I'm usually sceptical about these things but I wouldn't fill up without this now. http://www.pd-5england.co.uk/ A bottle lasts me about a year as it's only 10ml per 40L. I'm in Belfast though and I thought the fuel issue was only affecting the south of England? Link to comment Share on other sites More sharing options...
STA3 Posted March 20, 2007 Report Share Posted March 20, 2007 Hi All Just to draw a line under my original post I have now had my thermostat replaced and everything is now good in the world. My temp gauge is now getting up to and staying at 90 and my idle is steady as you like at 860 rpm even when free wheeling to a stop. So if you temp gauge is low and you have an eratic idle try getting you thermostat replaced. Link to comment Share on other sites More sharing options...
AudiLad Posted April 19, 2007 Report Share Posted April 19, 2007 Hey, My idling problem has just gone back to eratic a few days ago since I cleaned it out a few months ago. Im wondering whether I should try disconnecting the battery to reset the ecu but unsure on the procedures? What do you think "Wayneo1988"? Thanks Link to comment Share on other sites More sharing options...
AudiLad Posted April 19, 2007 Report Share Posted April 19, 2007 Just another question (sorry) if I disconnect the battery will I need to programme my remote fob key again? I have a 1998 Audi A3 Link to comment Share on other sites More sharing options...
safety69 Posted April 20, 2007 Author Report Share Posted April 20, 2007 hello mate, what i did was, i disconnected the battery neutral first, and i took my air housing off and the air hosing off so i had room to work. I disconnected the throttle cable and then sprayed the inside of the throttle body carefully and wiped it clean using a clean cloth, once nice and clean, i reconnected the battery and started it leaving it to idle with no throttle, but with all the high power drawing equipment on such as screen heaters, radio bright lights for about 2 minutes, before turning it all off and going for a good drive covering most of the rev range in all gears. ever since touch wood its been fine. What you could also try is someone with vag-com to check the postion of the trottle body and wether its ok. Link to comment Share on other sites More sharing options...
AudiLad Posted April 21, 2007 Report Share Posted April 21, 2007 Thanks for that! I disconnected my battery for about 20mins the other day and reset but this made no difference, so the next day I cleaned the throttle body myself with it still connected using carb cleaner. Took a few goes to start and once started, it took a few seconds for the revs to smooth out, but the acceleration now is responsive, smooth and not jerky as it was before. Lets just see how long it lasts... Link to comment Share on other sites More sharing options...
j4ck100 Posted July 18, 2011 Report Share Posted July 18, 2011 Hi All Late bump, I know. I have just bought an Audi A3 1.6 2000 , and it has developed the erratic idling and jerky acceleration, and some times near total loss of power. Am going to clean the Throttle Body later this afternoon with some carb cleaner, is this the best guess as to how to solve the problem? When you start the car, the revs fall to about 400, so the car nearly stalls, then the ecu picks it back up to 1k, and then it falls again. This is annoying as said before, as the car wont move by just lifting the clutch as it should do, as it stalls due to lack of power, and when moving off from lights and such, I find myself revving to 2-3k in order to not stall. Thanks Jack Link to comment Share on other sites More sharing options...
Hopsta Posted July 18, 2011 Report Share Posted July 18, 2011 Sounds like the car is in limp mode, need to get on to a diagnostic tool to find out what the ECU is reporting Welcome to TSN too Link to comment Share on other sites More sharing options...
