compbuild Posted February 26, 2007 Report Share Posted February 26, 2007 I have a 2002 Mk4 Golf and I have just fitted a VW Gamma Radio and a VW in dash 6 CD changer above it. My question is this. If the radio or CD player is on when the Car is switched off and the key removed, should it come back on the next time the car is started and be on the same radio station or start playing the CD from where it left off. At the moment when you switch the car on again the radio is turned off and if I turn it on and select the CD it just starts from Disk 1 track 1 and not where it was. I hope you understand what I mean as it sounds a bit funny written down. Am I missing a permanent live that would keep the memory of the CD player and should the radio be on when I start the car? Thanks Link to comment Share on other sites More sharing options...
ACA_Chap Posted February 26, 2007 Report Share Posted February 26, 2007 How did you wire the stereo in - whas it using the standard loom and attachement or did you individually connect the wires? Also can you operate the stereo with the key out of the ignition? Link to comment Share on other sites More sharing options...
compbuild Posted February 26, 2007 Author Report Share Posted February 26, 2007 Haven't tried with the key out of the ignition yet, will do tonight. I used the standard loom but somebody had messed about with it before I got the car, they had an after market head unit, I thought I had it back to normal but maybe not, how would I check Link to comment Share on other sites More sharing options...
ACA_Chap Posted February 26, 2007 Report Share Posted February 26, 2007 Try the key first. If it's not working with the key out of the ignition that explains why there's no power. If that doesn't solve it you can wire it all in individually. Out of interest where did you get the headunit and 6 cd changer from and how much did you pay? I'm looking to do the same for my mum's car. Was it a straight install or did you need to get any other parts? She has a panasonic head unit at the moment and the cbby hole above it. Link to comment Share on other sites More sharing options...
compbuild Posted February 26, 2007 Author Report Share Posted February 26, 2007 I got it off ebay for £160 delivered, it was a very easy install, there is a triangular space that cam with it to fit between the two unit but I didn't see any need for it, make sure you get the lead for the illumination of the changer with it, if you buy both head unit and changer it should be there Where would I find a wiring diagram for wiring it individually? Link to comment Share on other sites More sharing options...
ACA_Chap Posted February 26, 2007 Report Share Posted February 26, 2007 IF the install was working properly with the old headunit, you could work out what each wire if for by tracing back from the manual of the aftermarket unit (if that makes sense). HAve you wired the VW adapter back in to connect to the gamma unit? Is the unit new of 2nd hand? (it might be faulty?) Link to comment Share on other sites More sharing options...
compbuild Posted February 26, 2007 Author Report Share Posted February 26, 2007 The unit is second hand but I have also tried the beta out of my wifes Bora and it behaves the same, Should the radio be on when I turn the car on or does a VW not work like that? Link to comment Share on other sites More sharing options...
ACA_Chap Posted February 26, 2007 Report Share Posted February 26, 2007 I *think* it remembers the last setting. You can def turn it on without the key in the ignition tho - so like I said - that would be my first port of call. How have you wired it in? Have you wired the VW connector back in or is it individual wires? Link to comment Share on other sites More sharing options...
compbuild Posted February 26, 2007 Author Report Share Posted February 26, 2007 I have wired the VW connector back in and plugged it into the Gamma Link to comment Share on other sites More sharing options...
ACA_Chap Posted February 26, 2007 Report Share Posted February 26, 2007 OK - how did you wire the VW unit back in and was that new or 2nd hand? Link to comment Share on other sites More sharing options...
compbuild Posted February 26, 2007 Author Report Share Posted February 26, 2007 The connector was just coming out of the wiring loom, when I first put the gamma in it didn't power up so I had to change one of the wires can't remember which now. Is there somewhere that has a diagram of the colours of the wires and which bit of the connector they should go into? Link to comment Share on other sites More sharing options...
Froggy Posted February 26, 2007 Report Share Posted February 26, 2007 The connection marked UB on the lid should have the permanent supply. The other connection (S-Kont?) should be the ignition supply. (from memory sorry can't remember the wiring colours...) Link to comment Share on other sites More sharing options...
ACA_Chap Posted February 26, 2007 Report Share Posted February 26, 2007 I'd pay a visit to a VW dealer and they should fish one of these out for you F.O.C. Failing that a trawl through the internet should get you one (uk mkiv's website might be a good start). Link to comment Share on other sites More sharing options...
mb Posted February 26, 2007 Report Share Posted February 26, 2007 This shouldn't be very hard to get right. If both are VW units then both should have pin outs on the top of them so you should be able to see which wire is going where. The problems start if one of them is CAN & the other not - can you post a pic of the adapter, pinouts etc. as really the cars wiring should fit both boxes without the need for an adapter. Does the new one have a "quadlock" adaptor (really big box) as they use CAN whereas your original stereo probably did not. I have gone the other way & converted from OEM CAN (Double Din Delta) to non CAN (MFD) so know where to find the right wires once we know what you need to do ! Link to comment Share on other sites More sharing options...
compbuild Posted February 27, 2007 Author Report Share Posted February 27, 2007 Working now, thanks a lot for all your help everyone, it turns out I had to switch round the red and white wire with the yellow and red Link to comment Share on other sites More sharing options...
